Like Tree128Likes
Tekno NB48 2.0
    Hide Wikipost
Old 09-10-2019, 04:53 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48 2.0
Last edit by: tobamiester
Old 09-18-2019, 02:27 PM
  #46
TAW
Trader Rating: 18 (100%+)
Any idea when the manual will be posted online?
TAW is offline
Old 09-18-2019, 03:18 PM
  #47
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Now
TAW and kryss like this.
Matthew_Armeni is offline
Old 09-19-2019, 05:37 AM
  #48
Mine shipped from Amain 16th-on its way to the middle east--yeah
nitrorig is offline
Old 09-20-2019, 06:06 AM
  #49
Big Will's Avatar
New to Tekno. Looking at the parts list, are there only one length to both front and rear shocks? Only one shock shaft and shock boot part numbers listed (non-optional parts).
Big Will is offline
Old 09-20-2019, 07:02 AM
  #50
FastPete's Avatar
Trader Rating: 44 (100%+)
Correct front and rear are the same now. IE: Shaft is TKR6017, option is TKR6017T
Big Will likes this.
FastPete is offline
Old 09-20-2019, 08:13 AM
  #51
Default long rear tower
whats the reason for the longer rear shock tower?
sp88 is offline
Old 09-20-2019, 09:18 AM
  #52
Big Will's Avatar
I guess if you want the taller rear tower you need the optional XL shock shafts for the rear shocks
Big Will is offline
Old 09-20-2019, 09:32 AM
  #53
Mickey_B's Avatar
Trader Rating: 7 (89%+)
Default Gear Box
Anyone have an extra front gear box they could sell. I was putting my kit together yesterday and put the front screw in on the A block without the bumper and broke some of the plastic that holds the small screw underneath for bottom cover. Thanks they show out of stock on the Tekno site.
Mickey_B is offline
Old 09-20-2019, 09:34 AM
  #54
You'll actually want the long shock bodies, not the shafts.
The tall rear tower with the long shock bodies makes the car a little less responsive and possibly a little easier to drive (depending on you driving style).
Old 09-20-2019, 09:46 AM
  #55
I have a mp9 tki4. Do you know if the way of driving this car is very different? In coparation with the Kyshos are more durable?
cflopes is offline
Old 09-20-2019, 09:50 AM
  #56
So we should use the 122mm shafts in the 137mm bodies with the longer rear tower? just making sure i read that correctly.
sp88 is offline
Old 09-20-2019, 10:05 AM
  #57
Big Will's Avatar
Ok, thank. I haven't seen the shock body yet. I think someone just asked but would I run the regular shaft with that or the longer shaft?
Big Will is offline
Old 09-20-2019, 10:27 AM
  #58
I can't comment on the driving style of the MP9 as I haven't driven in quite a while and when I did it was only for a few laps. Durability wise I would like to think that our car is at the top of the list of all the current buggies on the market.
Yes, that's correct.
Keep the shaft that comes with the car (the 122mm one, TKR6017 or TKR6017T) and use the 137mm body (TKR6060).
By running the tall tower with the long body and short shaft you'll maintain your up and down travel but you'll gain better volume compensation. The shock won't pack quite as hard and it will be more linear throughout the stroke. It should also be more consistent over a long run. It's a subtle change but one I feel is worth trying. If you're track has a lot of switchbacks or quick "S" sections the short tower should be faster. If your track is bumpy, especially in areas where you are heavy on the brakes, the tall tower should be more forgiving.
gt racing likes this.
Old 09-20-2019, 10:36 AM
  #59
Big Will's Avatar
Matthew, Thank you for the explanation!! That really helped a lot
Big Will is offline
Old 09-20-2019, 03:21 PM
  #60
Mickey_B's Avatar
Anyone built there clutch yet. This damn thing is near impossible to get screws through.
Mickey_B is offline
