Tekno NB48 2.0
#48
Mine shipped from Amain 16th-on its way to the middle east--yeah
#51
whats the reason for the longer rear shock tower?
#53
Anyone have an extra front gear box they could sell. I was putting my kit together yesterday and put the front screw in on the A block without the bumper and broke some of the plastic that holds the small screw underneath for bottom cover. Thanks they show out of stock on the Tekno site.
#55
I have a mp9 tki4. Do you know if the way of driving this car is very different? In coparation with the Kyshos are more durable?
#56
So we should use the 122mm shafts in the 137mm bodies with the longer rear tower? just making sure i read that correctly.
#58
By running the tall tower with the long body and short shaft you'll maintain your up and down travel but you'll gain better volume compensation. The shock won't pack quite as hard and it will be more linear throughout the stroke. It should also be more consistent over a long run. It's a subtle change but one I feel is worth trying. If you're track has a lot of switchbacks or quick "S" sections the short tower should be faster. If your track is bumpy, especially in areas where you are heavy on the brakes, the tall tower should be more forgiving.
