New X10P4 Touring Car From MLP
#1187
I would be looking at a conversion kit for the stock car, but with a better motor plate, alloy front and rear bulkheads and the Evo5 steering, let me know how much the chassis and bits would be Marty, and how little I would have to send you, as it ain't cheaping sending the stuff from the UK to USA.
#1189
Originally Posted by Marty Peterson
Jamie when you get your car post pictures of it ok. Please!
Here is the block sheets again and Justins car!
Jamie
#1190
Tim And Cookie = what ever you two work out ok I just need to cad the TA05 ok.
I would go with the 415 MRE Bulk heads and my motormount with the TA05 Belts and MRE Diffs! that would make it the same as the TA05 Motor location and belt leights and we can do the Suspension in TA05 or 415!
#1191
Well the car handled pretty good today. For only running it on sat. an then today I still have some setup to do to get it better. I guess I didn't do to bad. Qualified 4th. Got hung on a wall on the second lap and came out 6th. Ended up finishing the race in 4th out of like 25 all together in stock foam. I will have to get the exact number of entries. Not positive on how many there were. Changed the springs and I'm running 60 weight oil in the front and 40 in the rear. the other 3 that beat me had alot more motor so I guess I need to get some better motors!I also took 3rd in 19T foam. Only 4 in that class and again I needed more motor. Hope you all had a Happy New Year!! I know I did!!
#1193
Justin check out these motors ok!
Team br00d Racing Motors
http://www.teambrood.com/catalog/index.php
Click the Link and look around and Email EddieO with what you want and tell him what your racing /Touring Carpet Foam! Stock and 19T and tell him you need a price on the 2 best motors he has ok.
Also Check this one out as well and do the same ok.
http://www.axiommotors.com/
Blueprinted EPIC Cobalt 27 w/XXX Brushes
Blueprinted Checkpoint Money 19t
#1194
#1195
Originally Posted by Kropy
How did your car handle after I helped you with your setup?
#1196
Hey Marty could u please pm me tracking info.
#1198
jtracker Way to go it was at the track and Running! I will keep working on getting motors for us but till then do what you can.
What motor are you running now?
Setup will come as you run it! keep up the good work.
Great to hear keep us up to date!
I was running a monster stock motor and phantom.
