Help starting engine
This is embarrassing but I can't get my engine to fire...
This is my first nitro build (Losi 8T). I had my motor broken in by Adam Drake and got everything installed today, I should be ready to go.
I put the glow plug on (confirmed its charged and lighting up), place the truggy on the starter, open the carb, push down, and.... nothing.
I'm not exactly sure what is supposed to happen. I've never used a starter.
The flywheel doesn't appear to be spinning and I can't even rotate it by hand. It does seem fuel has been sucked into the tube.
I'm really not sure what to even check. Help!#?
Did you heat the engine to about 200 degrees before starting?
Untighten your plug half out, and then put your igniter on. Push the car down, it will spoil some fuel but it doesn't matter. When it starts tighten your plug, and then you're ready to go.
Or just replace your plug..
Thats my opinion😀
Sorry for bad English, but hope you understand😀
Thats my opinion😀
