Like Tree2Likes
  • 1 Post By hansi31
  • 1 Post By mstrfahrenheit
Help starting engine
Old 02-09-2018, 09:10 PM
Default Help starting engine
This is embarrassing but I can't get my engine to fire...
This is my first nitro build (Losi 8T). I had my motor broken in by Adam Drake and got everything installed today, I should be ready to go.
I put the glow plug on (confirmed its charged and lighting up), place the truggy on the starter, open the carb, push down, and.... nothing.
I'm not exactly sure what is supposed to happen. I've never used a starter.
The flywheel doesn't appear to be spinning and I can't even rotate it by hand. It does seem fuel has been sucked into the tube.
I'm really not sure what to even check. Help!#?
mstrfahrenheit is offline
Old 02-09-2018, 09:18 PM
After researching I may have hydrolocked it, thats why it wont rotate. Found some instructions on how to deal with that, will give it a try in the am.
I also don't think I primed as per what I just read... Growing pains I guess
Old 02-09-2018, 09:37 PM
Did you heat the engine to about 200 degrees before starting?
Cardiak is offline
Old 02-09-2018, 11:32 PM
Untighten your plug half out, and then put your igniter on. Push the car down, it will spoil some fuel but it doesn't matter. When it starts tighten your plug, and then you're ready to go.
Or just replace your plug..
Thats my opinion😀
Sorry for bad English, but hope you understand😀
Houmb likes this.
hansi31 is offline
Old 02-10-2018, 03:23 AM
Trader Rating: 89 (100%+)
Definitely need to heat it up. My protek samurai after 15 tanks will not turn over without heating it up. A heat gun or engine warmer is a must.
b121774 is online now
Old 02-10-2018, 03:20 PM
to prime the engine for starting, place the truggy down on the box. Do not put the glow ignitor on the plug. Hold your finger over the exhaust and press down on the truck. Look for the fuel to go into the inlet of the high speed needle. You should be good to go then.
Evoking1230 is offline
Old 02-10-2018, 09:48 PM
alright, freed it up out of hydrolock.
wasn't heating so i picked up a heat gun this evening. Will try again in the am.
thanks!
stanleyw808 likes this.
Old 02-11-2018, 12:17 PM
That did it! Heating then priming and she started like a champ.
Thanks guys.
