Team C 1/8 GT car
#1381
Nice paint work
#1384
PanAm Nats setup 2014
REAR:
REAR:
- 3* camber
- 2.5 toe in
- 1.5* anti squat
- 9.5mm ride height
- shocks outside on arms middle on tower
- Links mid on AL hub inside middle on tower
- 1500 dif fluid (not 15,000)
- 1300CST shock oil with RCShox dual stage pistons
- The just released Team C ultra hard springs
- 6mm droop
I learn a lot by reading what you write...
and I greatly appreciate the technical discussions ... I thank you for that ...
but I not understand the technical reason why you used a diff oil so thin...
The teamC recommends : 10000 front and 5000 rear... but I do not understand even this choice... because, in general , in the class GT is using 100000 front and 30000 rear...
if anyone knows I thank him
p.s: sorry for my bad english
#1385
Hi,
TeamC(the factory) do not race the cars, this class doesnt even really exist overseas and the manual was written before the class ever existed!. What are the fastest rubber tire RC cars? 10th scale TC and how are they setup? Spool front and very light rear oil. This allows for very good turn in and massive on power steering so the car basically follows where ever the front wheels are going. Since we do not use a center diff power is equally delivered to the front and rear and with the super thick front fluid you dont really have to worry about diffing out and losing traction.
The class you refer to is Serpent and that car is a different animal, the TeamC car does not have kickup so we lose initial weight transfer. You cannot set this car up like a Serpent, difs are different and many other things. 30,40,50k rear fluid will not work in this car very well.
#1386
GT has been raced for many years in: Japan, Philippines, Peru, Chile, Argentina, Ecuador, Panama, Mexico, Brazil, Puerto Rico, Dominican Republic, Jamaica, Bahamas, Canada, Sweden, Switzerland, Finland, Great Britain, Spain, Portugal, Canary Islands, Italy, Netherlands, Turkey, Greece, Germany, Australia (as well possibly others that escape me at the moment) and of course here in the USA.
All of the above GT racers and their racing groups existed long before your brands contemplating entering the existing GT racer arena.
#1387
MODERATOR PLEASE STOP THIS BEFORE IT GOES SOUTH
Actually Marcus, GT cars have existed and have been raced around the world for at least the past 8 years.
MOD please be aware.....
#1388
so what could be the reason to put 500000 front and 20000 rear ? (eg post 1334)
#1389
search mantisworx on youtube and you will see what i am talking about!!
#1390
not all setups will be the same Frenchies driving style is not as aggressive as mine. i tend to drive my cars like 1/8GP cars , lots of on power steering and i am on the gas before the Apex. I also build my front dif with double shims to basically get it as close to a spool as i can. With my setup you dont have to worry about the rear stepping out uncontrollably , and if it does you just drive through it. with the higher rear fluid the rear never really plants and is always dancing around. with the high rear fluids you have more of a tendency to "loop out" on exit if your not careful.
i have GT8L (long version )... so i setup as you say or have I to do some changes because that's the long version?
consider that I have two GT8L with two different engines...
Car A) novarossi Brave .21
Displacement: 3,49 cc
R.P.M. (max power): 38.500 RPM
Practical range: 6.000-45.000 R.P.M.
Bore x stroke: 16,26x16,80 mm
Sleeve: 5 ports
Rear ball bearings: steel
Front ball bearings: steel
Crankshaft: 14 mm - turbo
Carburetor: aluminium - 9mm - slide
Glowplug: Turbo (C6TF)
Exhaust position: rear
Starting: -
Weight: 348 g
Car B) novarossi ROMA .25
Displacement: 4,04 cc
R.P.M. (max power): 37.500 RPM
Practical range: 6.000-42.100 R.P.M.
Bore x stroke: 17,10x17,60 mm
Sleeve: 7 ports
Carburetor: plastic - 9 mm - reverse
Glowplug: Turbo (C6TGC)
Exhaust position: posteriore
Starting: -
Weight: 374 g
many thanks
#1391
you convinced me ... I also hope to be able to drive like 1/8GP...
Sleeve: 5 ports
Starting: -
Weight: 348 g
Sleeve: 7 ports
Starting: -
Weight: 374 g
many thanks
Sleeve: 5 ports
Starting: -
Weight: 348 g
Sleeve: 7 ports
Starting: -
Weight: 374 g
many thanks
engine wise your kinda in no mans land, problem is that the TeamC gears are really short so the long stroke roma is not going to be optimal, the 5pt with a short header and 9886 will probably be your best combo, this is assuming your track is fast. if its a short choppy track either engine will be fine but use 45/41 spur gears.
#1392
ok thanks
here you can see my track
https : // plus.google.com/104836729692643813335/photos/photo/5926930643108298898?hl=it%26socfid=web:lu:kplacepa geimage%20%26socpid=1!5sRoad%20Race%20Riccione%20-%20Cerca%20con%20Google&sa=X&ei=d_PaU77eELKV7AalpY CYBA&v%20ed=0CGwQoiowDQ&pid=5926930643108298898&oi d=104836729692643813335
in A car with novarossi Brave .21 i I thought 16/20 pinion and 45/41 gear
in B car with novarossi ROMA .25 i I thought 17/21 pinion and 45/41 or 46/42 gear
What do you think ?
What do you think ?
#1393
ok thanks
google.it/maps/uv?hl=it&pb=!1s0x132cdd37dbda0e9f:0x65b15ff71c0b67 55!2m5!2m2!1i80!2i80!3m1!2i100!3m1!7e1!4shttps://plus.google.com/104836729692643813335/photos?hl%3Dit%26socfid%3Dweb:lu:kplacepageimage %26socpid%3D1!5sRoad+Race+Riccione+-+Cerca+con+Google&sa=X&ei=d_PaU77eELKV7AalpYCYBA&v ed=0CGwQoiowDQ
What do you think ?
What do you think ?
#1394
#1395
