Like Tree759Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 03-08-2018, 08:01 PM
  #1321
Regional Moderator
disaster999's Avatar
careful with aftermarket belts, Probably not this specific one, but ive heard people saying some aftermarket white belts are thicker than stock and it pinches between the pulley and the bearing.
Marcos.J and team green like this.
disaster999 is offline
Old 03-09-2018, 07:57 AM
  #1322
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
these were on the car when i got it so they are good for stock , waiting on the stock belts so i can throw my SpeedZone 4.5 in
Marcos.J is offline
Old 03-09-2018, 08:05 AM
  #1323
SLOW 77's Avatar
Trader Rating: 31 (100%+)
Is there any tips or new setups for asphalt; like we are seeing with the latest carpet setups?
I really like that Robert and the team are strait forward with what is working best!
Those carpet changes made a world of difference for me.
I am switching my car back to Asphalt and curious of any new setup changes.
Marcos.J likes this.
SLOW 77 is offline
Old 03-09-2018, 09:46 AM
  #1324
Super Moderator
Marcos.J's Avatar
I知 working on one right now will be using it at out covered outdoor track tomorrow and on Sunday I知 going to Valkaria Raceway were the electric on road nationals was held a few years ago. I can send it to you Sunday night.if it looks like a possibility of rain on Sunday I will be heading to the indoor carpet track and test the front end plates that I made.
Bartolo Racing likes this.
Marcos.J is offline
Old 03-09-2018, 09:50 AM
  #1325
SLOW 77's Avatar
Sounds good Marcos!
SLOW 77 is offline
Old 03-09-2018, 10:42 AM
  #1326
No problem with these, got them on both of my cars with no issues(other than a little break-in). A couple of packs for practice and good-to-go.👍
casrcr is offline
Old 03-09-2018, 03:13 PM
  #1327
Super Moderator
Marcos.J's Avatar
No issues here either
Marcos.J is offline
Old 03-11-2018, 05:45 PM
  #1328
Bartolo Racing's Avatar
Trader Rating: 18 (100%+)
Steering rack bearing size?? Thank you
Bartolo Racing is offline
Old 03-12-2018, 05:42 AM
  #1329
TomTurbo's Avatar
anyone of you using a full set of titanium screws?
whats the weigth advantage?
thx!
TomTurbo is offline
Old 03-12-2018, 01:09 PM
  #1330
lbckevin's Avatar
Trader Rating: 107 (99%+)
thx!
I used Tworks and it saved 24 grams
lbckevin is offline
Old 03-12-2018, 01:25 PM
  #1331
Trader Rating: 22 (100%+)
Switched from the TOP cars? Almost ready to pull the trigger on one! how you liking them chris? good on the bumpy tracks?
noproblems209 is offline
Old 03-12-2018, 02:18 PM
  #1332
kunemlavat's Avatar
Love the Mugen Brand! Thinking about getting one of these to replace a current TC.
What should I look out for? Mods needed ect..I知 thinking of Mugen, Xray, Yokomo, or Associated. But leaning to Mugen
kunemlavat is offline
Old 03-12-2018, 02:34 PM
  #1333
chiefj48's Avatar
I have a new sealed kit for sale if interested pm me.
gijoe64 likes this.
chiefj48 is offline
Old 03-12-2018, 02:36 PM
  #1334
Super Moderator
Marcos.J's Avatar
Originally Posted by Marcos.J
I have seen where you can mount the servo plate to the chassis to take some flex ,I also added this little straps to it now it has very little flex. Will try it out this weekend.
The car is dialed for asphalt out of the box
The above mod for black crc is what I have done with the car. Car has next to no flex with it
Marcos.J is offline
Old 03-12-2018, 06:30 PM
  #1335
kunemlavat's Avatar
That looks nice, I知 still deciding because the locals have yokomo or x Ray.(no local parts support) but all the off road mugens I致e had broke very rarely.
I知 still trying to decide but I知 pretty sure it will be a used tc. Although I will love a new kit I just can稚 afford it
