Like Tree759Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 02-22-2018, 05:51 AM
  #1306
Team EAM
Trader Rating: 79 (100%+)
More alumn chassis, top decks and other parts just in!
EAMotorsports is offline
Old 03-03-2018, 02:45 PM
  #1307
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Ran the MTC1 today for the first time on low-medium asphalt with the pretty much bone stock set up. Car was very easy to drive .
lbckevin, SLOW 77, LOW ET and 1 others like this.
Marcos.J is offline
Old 03-05-2018, 01:24 PM
  #1308
gijoe64's Avatar
Trader Rating: 30 (100%+)
OK guys I really need your help, I am having major steering issues with my MTC1.
Im using a R1 servo with Xray servo saver.
Issue: Cannot get car to track straight, the car does not steer consistently and the car always push to the right and not the left.
I have mechanically properly adjust my steering rack.
I have made sure my steering rack does not bind.
I did check the servo to see if it was stripped.
I have checked the car for tweek
I have checked the drivetrain to see if it was bound.
I am running on black carpet, tight track
I need your wisdom thanks guys
gijoe64 is offline
Old 03-05-2018, 02:42 PM
  #1309
On power, off power, both?
casrcr is offline
Old 03-05-2018, 03:15 PM
  #1310
gijoe64's Avatar
On power push
gijoe64 is offline
Old 03-05-2018, 03:29 PM
  #1311
Super Moderator
Marcos.J's Avatar
On power push
Try the stock mugen servo arm
Marcos.J is offline
Old 03-05-2018, 03:32 PM
  #1312
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Check that the servo mounting screws haven't come loose. Also check that your endpoints are set evenly
GrandeGixxer is offline
Old 03-05-2018, 03:35 PM
  #1313
gijoe64's Avatar
Thats my next move
Marcos.J likes this.
gijoe64 is offline
Old 03-05-2018, 03:42 PM
  #1314
gijoe64's Avatar
Done that thanks, But im gonna take the xray servo saver off and replace it with the mugen. and recheck
gijoe64 is offline
Old 03-06-2018, 10:00 AM
  #1315
Super Moderator
Marcos.J's Avatar
Ready for the weekend
Marcos.J is offline
Old 03-08-2018, 08:09 AM
  #1316
Super Moderator
Marcos.J's Avatar
I have seen where you can mount the servo plate to the chassis to take some flex ,I also added this little straps to it now it has very little flex. Will try it out this weekend.
Attached Thumbnails Mugen MTC1-75330a26-5284-4a08-a866-89358b59ac42.jpeg   Mugen MTC1-43d6e8e0-76ae-4260-9082-bac5244f8f5b.jpeg   Mugen MTC1-d945e187-1b11-4a21-ab51-360cc793dbf9.jpeg
Marcos.J is offline
Old 03-08-2018, 06:42 PM
  #1317
team green's Avatar
Trader Rating: 14 (100%+)
What belt is that?
team green is offline
Old 03-08-2018, 06:52 PM
  #1318
Regional Moderator
disaster999's Avatar
Xenon
disaster999 is offline
Old 03-08-2018, 06:55 PM
  #1319
team green's Avatar
Originally Posted by disaster999
Xenon
Thanks. Where can I order from?
Old 03-08-2018, 07:46 PM
  #1320
Super Moderator
Marcos.J's Avatar
https://www.apexrc.com/products/xeno...white-belt-s3m
team green likes this.
Marcos.J is offline
