Schumacher R12 Fusion
#16
how does the car look like? any pic?
whats the strong point on the car?
does it have centax? metal shock?
roll bars?
roll bars?
#18
Pass on the kit setup in the manual I'm not sure where they got that setup, but its not that good
Please refer to your setup sheet for setup #'s.
Front
tower/1
bulkhead/2
arm/2
hub/2
steering/2
arm sweep/0
piston/#2 vari
oil/55wt
spring/yellow
droop/2mm
swaybar/stock
castor/thin kwikclip back
camber/neg 1
toe/1deg out
ride height/4.5mm
tire/Take-off 40's(purple) 26mm
diff/yes
Rear
tower/2
bulkhead/2
arm/2
hub/2
piston/#2 vari
oil/50wt
spring/red
droop/3mm
swaybar/stock
in-board toe/0
toe-in/2.5deg
rear arm/spaced rear
camber/neg 1
ride height/5mm
tire/Take-off 40's(purple) 30mm
This setup is for a stock R12 and will be very comfortable to drive (pushy). The oneway is a huge advantage and will give the car way more steering, but will be harder to drive.
I will post a setup using all the hop-ups next.
Front
tower/1
bulkhead/2
arm/2
hub/2
steering/2
arm sweep/0
piston/#2 vari
oil/55wt
spring/yellow
droop/2mm
swaybar/stock
camber/neg 1
toe/1deg out
ride height/4.5mm
diff/yes
Rear
tower/2
bulkhead/2
arm/2
hub/2
piston/#2 vari
oil/50wt
spring/red
droop/3mm
swaybar/stock
in-board toe/0
toe-in/2.5deg
camber/neg 1
ride height/5mm
#19
Tricked out R12
Front
Mission tower/3
bulkhead/alloy
arm/1
hub/alloy with low-ball
steering/2
arm sweep/0
piston/#2 vari
oil/60wt
spring/28lb
droop/2mm
swaybar/pro-bar mounted to lower arm
camber/neg 2
toe/0
ride height/4.5mm
tire/Take-off 40's(purple) 26mm Go to 43's front when very high-bite
oneway
Rear
Mission tower/3
bulkhead/alloy
arm/1
piston/#2 vari
oil/50wt
spring/25lb
droop/3mm
in-board toe/0
toe-in/2.5deg
camber/neg 1.5
ride height/5mm
Both setups use protoform stratus 2.1
This setup has tons of corner speed
Front
Mission tower/3
bulkhead/alloy
arm/1
steering/2
arm sweep/0
piston/#2 vari
oil/60wt
spring/28lb
droop/2mm
camber/neg 2
toe/0
ride height/4.5mm
oneway
Rear
Mission tower/3
bulkhead/alloy
arm/1
piston/#2 vari
oil/50wt
spring/25lb
droop/3mm
in-board toe/0
toe-in/2.5deg
camber/neg 1.5
ride height/5mm
#20
Hay pat how you doing,I have just been waiting for the car to come out.Thanks for the set-up PW,I think I can find somthing in there to start with.Thanks agian Doug Lemmons
#22
No problem doug....
Fred....I actually really like the stock pipe so far with 3 different engines (Picco, Rossi & Sirio)
#24
I can't believe I forgot about the pistons....#2 vari-piston.
The stock pipe is legal as far as I know
#25
I was there when The OLD MAN brought it in. Damn could the car roll anymore? Free little thing ain't it Fredo. I didn't get to see it race but it was quick. When the car dies and then rolls another 50 or so ft, thats a free car. Great job on it Fredo. Just remember come May 11. I'm back and the NTC-3 is back in action. All though Dan might just mistake us as boards, watch out!!
#27
Hey Fred...Yes, I'm running the stock pipe with the baffle.
#29
Yeah spooky, that weekend really was a washout!!!!
