Old 04-23-2003, 02:00 AM   #16
how does the car look like? any pic?
whats the strong point on the car?
does it have centax? metal shock?
roll bars?
fuse01 is offline   Reply With Quote
Old 04-23-2003, 07:36 AM   #17
Suspended
Trader Rating: 28 (100%+)
Default Hey Doug !
The setup is.............BUY A MUGEN!
Actually I look forward to seeing your car because I know you fly with schumacher.
racenut123 is offline   Reply With Quote
Old 04-23-2003, 08:11 AM   #18
PW
PW's Avatar
Send a message via AIM to PW
Pass on the kit setup in the manual I'm not sure where they got that setup, but its not that good
Please refer to your setup sheet for setup #'s.
Front
tower/1
bulkhead/2
arm/2
hub/2
steering/2
arm sweep/0
piston/#2 vari
oil/55wt
spring/yellow
droop/2mm
swaybar/stock
castor/thin kwikclip back
camber/neg 1
toe/1deg out
ride height/4.5mm
tire/Take-off 40's(purple) 26mm
diff/yes
Rear
tower/2
bulkhead/2
arm/2
hub/2
piston/#2 vari
oil/50wt
spring/red
droop/3mm
swaybar/stock
in-board toe/0
toe-in/2.5deg
rear arm/spaced rear
camber/neg 1
ride height/5mm
tire/Take-off 40's(purple) 30mm
This setup is for a stock R12 and will be very comfortable to drive (pushy). The oneway is a huge advantage and will give the car way more steering, but will be harder to drive.
I will post a setup using all the hop-ups next.
PW is offline   Reply With Quote
Old 04-23-2003, 08:31 AM   #19
PW
PW's Avatar
Tricked out R12
Front
Mission tower/3
bulkhead/alloy
arm/1
hub/alloy with low-ball
steering/2
arm sweep/0
piston/#2 vari
oil/60wt
spring/28lb
droop/2mm
swaybar/pro-bar mounted to lower arm
camber/neg 2
toe/0
ride height/4.5mm
tire/Take-off 40's(purple) 26mm Go to 43's front when very high-bite
oneway
Rear
Mission tower/3
bulkhead/alloy
arm/1
piston/#2 vari
oil/50wt
spring/25lb
droop/3mm
in-board toe/0
toe-in/2.5deg
camber/neg 1.5
ride height/5mm
Both setups use protoform stratus 2.1
This setup has tons of corner speed
Old 04-23-2003, 06:36 PM   #20
Trader Rating: 18 (100%+)
Hay pat how you doing,I have just been waiting for the car to come out.Thanks for the set-up PW,I think I can find somthing in there to start with.Thanks agian Doug Lemmons
Doug Lemmons is offline   Reply With Quote
Old 04-23-2003, 08:24 PM   #21
Trader Rating: 244 (99%+)
Thanks Paul you da man. I will let you know how I make out this weekend. One other question what pipe do you reccomend for a .12 Picco.
Fred Perkins is offline   Reply With Quote
Old 04-23-2003, 08:39 PM   #22
PW
PW's Avatar
No problem doug....
Fred....I actually really like the stock pipe so far with 3 different engines (Picco, Rossi & Sirio)
Old 04-23-2003, 09:47 PM   #23
cool but its not legal for roar is it? do you run the baffel? what shock pistons are you running?
Old 04-24-2003, 07:48 AM   #24
PW
PW's Avatar
I can't believe I forgot about the pistons....#2 vari-piston.
The stock pipe is legal as far as I know
Old 04-24-2003, 06:45 PM   #25
Tweeter's Avatar
I was there when The OLD MAN brought it in. Damn could the car roll anymore? Free little thing ain't it Fredo. I didn't get to see it race but it was quick. When the car dies and then rolls another 50 or so ft, thats a free car. Great job on it Fredo. Just remember come May 11. I'm back and the NTC-3 is back in action. All though Dan might just mistake us as boards, watch out!!
Tweeter is offline   Reply With Quote
Old 04-25-2003, 04:44 AM   #26
Paul- Are you running the the baffel in the pipe?
Tweeter- Thank's dude. but the real thanks goes to schumacher. Cant wait to see you out at the track again.
Old 04-27-2003, 07:23 PM   #27
PW
PW's Avatar
Hey Fred...Yes, I'm running the stock pipe with the baffle.
Old 04-27-2003, 07:29 PM   #28
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Paul, bummer about the rain, I was looking foward to you and Dave running the R12's
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-28-2003, 07:50 AM   #29
PW
PW's Avatar
Yeah spooky, that weekend really was a washout!!!!
Old 04-30-2003, 03:54 AM   #30
ttt
schumacher fusion qcrvr R/C Items: For Sale/Trade 6 05-12-2004 07:30 PM
$200.00 for my SCHUMACHER FUSION R12 etips76 R/C Items: For Sale/Trade 0 10-23-2003 06:15 AM
Getting a new 1/10 which should i get a hpi rs4 3 or a schumacher fusion mohamed_own Nitro On-Road 9 10-19-2003 09:28 PM
looking for schumacher fusion.21 erand8976 R/C Items: Wanted to Buy 0 10-15-2003 10:30 PM
Schumacher Fusion Fusion Australian Racing 19 02-02-2003 07:06 PM
