Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1711
Hi. yes their were new parts and i did test many of them and liked some of them. I thought that the set up as a whole was in a different direction that i normally try and work in, so i think that had a lot to do with it. Normally i try and get steering from running less ackermann and stiffer front shocks and such, but with this set up i worked with softer front springs and a lot of ackermann to be easy on the front tires, then i worked more with weight distribution to get the steering back. I think in the end i had a set up that was not tuned in to a corner and had good traction without hurting the front tires too bad. I will post the set up for it worked great even without the new pieces.
#1712
Paul,
Which motor setting did you use (ratio + motor timing).
Which speedo setting did you use?
I guess you were using a 4.0T.
#1713
Thank's Paul to upload the set up.
What is the final weight of your car ready to race?
Also I see you generate a lot of overall traction how you planning to change it for much hotter conditions in the end of July?
#1714
Sifu,
Diffs down ?
Yet again trying to make sure we aren't asleep ?
btw, seeing you drive without sauce at the worlds wasn't surprising.... it reminds me of how good you are at car control... specifically the show you put on at the xray challenge in Portland a few years back, Nearly an entire lap in nitro where you switched on drift mode and counter steered your way around. It was brilliant...
Cheers,
Jake
Diffs down ?
Cheers,
Jake
#1715
Hi. The two piece front sus mount could help you a bit with steering but i wouldn't only look their, the car is surely tunable without worrying about sus mounts.
I would try adding some shimming to the steering ball studs. by shimming them forward 1mm it will give you less ackermann (tires will turn more equally) and the car should have more on power steering. That is what i would try first, secondly i would try and lay in the rear shocks
#1717
Hey Paul,
Was wondering on your 1/12 when you run mod or any class i guess, do you ever use your brakes, like a quick tap at the end of a straight or do you use zero brake in 12th scale? What about drag brake? Thank you!!!!! Chad
#1722
Sifu,
Diffs down ?
Cheers,
Jake
Diffs down ?
Cheers,
Jake
No problem
Typo BLS551, sorry
Thanks!
#1723
1480g? That's 100g above the limit!?
And of course ECS in front?
#1724
#1725
