Ko Propo VFS-1 ESC
#1606
19T Profile
Hi Guys
I have to race with a Team Orion 19T motor (ORI20033 – Element 19T motor – Revolution ) on a indoor carpet track (DHI-cup in Denmark) and I need a good profile for this race
I have looked on Kopropo.com , can I use the Kopropo profiles or can any of you help me, PLEASE
#1608
Originally Posted by TadehI
Exactly where are the profiles on the Ko Propo website? I would like to get my hands on some mod setups.
The exact web link, please.
Thankyou
Thankyou
scroll down and you'll see the different profiles.
Originally Posted by sbs
Hi Guys
#1609
sbs-
Is it for the VFS-1 or VFS-2000? If you need help, you can email me at [email protected]
subman-
The important thing about the cap is not only the uF capacity but the voltage and the resistance of the cap. Not all caps have the same resistance.
Using a cap rated at 10V gets very close to the limits of a voltage spike. Sometimes the voltage spike may go beyond 10V and could damage the cap and the esc.
-Robert
subman-
-Robert
#1611
hi anyone know the difference between each of these packs?
VFS-1 PRO Competition Value Set No.40144
VFS-1 J Value Set No.40141
VFS-1 PRO Value Set No.40140
#1612
The VFS_1 Pro Competition Value set includes the VFS-1 Pro Competition version, multi hand setting adapter and VFS-1 setting card. The VFS-1 Pro Competition version has the carbon fiber looking case with a very high thermo cut off.
the J value set is a prewired VFS-1 Pro.
all value sets come with the handheld adapter, setting card along with the esc.
#1613
if anyones looking I am selling my hara 2.1, vfs pro-1, pc cable and new type handheld adapter with card.
Dont get be wrong, in the right hands this is hands down the best esc...sadly, mine are not the right hands, could never get the profile to work quickly enough for me, took one or two runs...
#1614
If I want to set the throttle punch function to maximum effect (max punch),
what value (between 1-9) should I used?
I'm confused with the manual description for this one.
Any help would be appreciated.
#1615
#1616
Originally Posted by KO PROPO Staff
1 is the max throttle response.
#1617
So with '1', the ESC would feel the most punchy, thru 9 (the least punchy)? What about 'Off'?
And also I am a bit uncertain about Hi Point on the Helios when setting the VFS-1?
Should I set my Hi Points on the Helios at 100 or 150 before I set my VFS-1? Is there any difference between 100 or 150? What about Brakes?
Thank you for your time.
#1618
I am looking at buying the hara 2.1 version and wanted an insight of what the esc is like before I make my purchase. I also run a spektrum and a digitial servo (airtronics) and I read a few pages back that the BEC voltage had to be changed to 3.5V on the standard KO VFS-1 pro comp model, is this the same with the Hara 2.1?
Also, is it really necessary to run the heatsink when running touring car mod (7-9t) in fairly hot conditions (30'C+)? Finally, I was hoping to view the instructions for the esc (either the hara or the ko version) and I was hoping if someone could email me a copy of it?
My address is:
[email protected]
Much appreciated if anyone can help out.
My address is:
[email protected]
#1619
the instructions for teh esc are very simple, because you cannot program it without the hand held adaptor or PC cable, the instructions for that are more lengthy.
I would suggest downloading the ko software as that lets you see everything you could set on the esc.
#1620
Originally Posted by Kenneth Tan
Hi,
the throttle highpoint should be at 100 if you set it at 150 your car will have glitching problems. set brake at 150.
