Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 12-21-2005, 10:43 PM
  #1606
sbs
sbs's Avatar
Default 19T Profile
Hi Guys
I have to race with a Team Orion 19T motor (ORI20033 Element 19T motor Revolution ) on a indoor carpet track (DHI-cup in Denmark) and I need a good profile for this race
I have looked on Kopropo.com , can I use the Kopropo profiles or can any of you help me, PLEASE
sbs is offline
Old 12-21-2005, 10:58 PM
  #1607
subman's Avatar
Has anyone used a 2200 uF capacitor instead of the 2700 it comes with? I can just get 2200 for next to nothing.
subman is offline
Old 12-22-2005, 12:35 AM
  #1608
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by TadehI
Exactly where are the profiles on the Ko Propo website? I would like to get my hands on some mod setups.
The exact web link, please.
Thankyou
here's the link: http://www.kopropo.com/vfs_help.htm
scroll down and you'll see the different profiles.
Originally Posted by sbs
Hi Guys
look back several pages. other racers have posted different profiles. if you need anymore help, ask Robert for Mike Patterson's profile for 19T that was used a few years back.
Hebiki is offline
Old 12-22-2005, 10:39 AM
  #1609
sbs-
Is it for the VFS-1 or VFS-2000? If you need help, you can email me at [email protected]
subman-
The important thing about the cap is not only the uF capacity but the voltage and the resistance of the cap. Not all caps have the same resistance.
Using a cap rated at 10V gets very close to the limits of a voltage spike. Sometimes the voltage spike may go beyond 10V and could damage the cap and the esc.
-Robert
KO PROPO Staff is offline
Old 12-22-2005, 02:13 PM
  #1610
subman's Avatar
Very true but it is a 25v cap. My thinking was that I might use a smaller capacity cap on my 12th scale (4cell) and it would take less time to charge/discharge thus taking better advantage of the 4 cell setup. I could be totaly wrong in this thinking though
subman is offline
Old 12-25-2005, 12:59 PM
  #1611
hi anyone know the difference between each of these packs?
VFS-1 PRO Competition Value Set No.40144
VFS-1 J Value Set No.40141
VFS-1 PRO Value Set No.40140
Doomah is offline
Old 12-25-2005, 02:12 PM
  #1612
Hebiki's Avatar
The VFS_1 Pro Competition Value set includes the VFS-1 Pro Competition version, multi hand setting adapter and VFS-1 setting card. The VFS-1 Pro Competition version has the carbon fiber looking case with a very high thermo cut off.
the J value set is a prewired VFS-1 Pro.
all value sets come with the handheld adapter, setting card along with the esc.
Hebiki is offline
Old 12-25-2005, 02:48 PM
  #1613
BritRacer's Avatar
if anyones looking I am selling my hara 2.1, vfs pro-1, pc cable and new type handheld adapter with card.
Dont get be wrong, in the right hands this is hands down the best esc...sadly, mine are not the right hands, could never get the profile to work quickly enough for me, took one or two runs...
BritRacer is offline
Old 12-28-2005, 06:44 PM
  #1614
Piyo Piyo's Avatar
If I want to set the throttle punch function to maximum effect (max punch),
what value (between 1-9) should I used?
I'm confused with the manual description for this one.
Any help would be appreciated.
Piyo Piyo is offline
Old 12-29-2005, 09:09 AM
  #1615
1 is the max throttle response.
Old 12-29-2005, 10:01 PM
  #1616
Piyo Piyo's Avatar
OK. Thanks a lot
Old 12-29-2005, 10:19 PM
  #1617
Kenneth Tan's Avatar
Hi,
So with '1', the ESC would feel the most punchy, thru 9 (the least punchy)? What about 'Off'?
And also I am a bit uncertain about Hi Point on the Helios when setting the VFS-1?
Should I set my Hi Points on the Helios at 100 or 150 before I set my VFS-1? Is there any difference between 100 or 150? What about Brakes?
Thank you for your time.
Kenneth Tan is offline
Old 12-30-2005, 06:48 AM
  #1618
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
I am looking at buying the hara 2.1 version and wanted an insight of what the esc is like before I make my purchase. I also run a spektrum and a digitial servo (airtronics) and I read a few pages back that the BEC voltage had to be changed to 3.5V on the standard KO VFS-1 pro comp model, is this the same with the Hara 2.1?
Also, is it really necessary to run the heatsink when running touring car mod (7-9t) in fairly hot conditions (30'C+)? Finally, I was hoping to view the instructions for the esc (either the hara or the ko version) and I was hoping if someone could email me a copy of it?
My address is:
[email protected]
Much appreciated if anyone can help out.
DirtyDog3375 is offline
Old 12-30-2005, 06:57 AM
  #1619
BritRacer's Avatar
the instructions for teh esc are very simple, because you cannot program it without the hand held adaptor or PC cable, the instructions for that are more lengthy.
I would suggest downloading the ko software as that lets you see everything you could set on the esc.
Old 12-30-2005, 08:28 AM
  #1620
Originally Posted by Kenneth Tan
Hi,
the throttle highpoint should be at 100 if you set it at 150 your car will have glitching problems. set brake at 150.
goop is offline
