Like Tree195Likes
Novarossi engines thread
Old 04-15-2008, 11:39 AM
  #2626
asw7576's Avatar
Originally Posted by cdelong
Swap fuels..... Byron's, Tornado, Maxy's and give that a try..... maybe one range colder... C8TF. 25% is more than enough Nitro. You should be a ble to handle up to 250F with no problem. Are any of the rods loose? That will cause you to eat plugs like candy.
I'm running 0.9mm up north in 70- 80F temps. You may need another tenth to be safe. Any detonation pitting?
This time around, I'm gonna use C8TF.
I can't swap fuel, I still have plenty O'Donnell fuels 25%.
Any detonation pitting ? yes, the surface of the piston & underhead look like moon.
Thanks for the loose conrod tip.... I never knew that until today.
asw7576 is offline
Old 04-15-2008, 07:07 PM
  #2627
ohmygahitscoby's Avatar
Trader Rating: 17 (100%+)
Hey everyone. Does anyone know how to tell the difference between the Nova Mugen MT-12 and the MR-12. Also, what should be the running temp for these engines?
ohmygahitscoby is offline
Old 04-16-2008, 12:02 AM
  #2628
stefan's Avatar
The MT12 was NR's long ROD (not long stroke) engine, the MR12 is short rod engine, comparable to the NR RS12S1.
Both engines should run well around 110°C.
stefan is offline
Old 04-16-2008, 10:52 PM
  #2629
Trader Rating: 15 (94%+)
Default Novarossi PLus 12 3CT Tuned questions..
Hi guys i just got a Novarossi PLus 12 3CT Tuned.
Do novarossi sign "tuned" on the back of there crankshafts? i remember once seeing a crank signed "tuned" on the back.
What % fuel do these engines come shimmed for?
Thanks!
John
mrgsr is offline
Old 04-16-2008, 11:20 PM
  #2630
ezveedub's Avatar
I believe MR/GRP put tuned on the cranks, not Novarossi.
ezveedub is offline
Old 04-16-2008, 11:21 PM
  #2631
A mate of mine just told me the ones that said tuned were from the 2006 worlds
mrgsr is offline
Old 04-16-2008, 11:42 PM
  #2632
Team Kamikaze's Avatar
Thanks!
John
16%
Team Kamikaze is offline
Old 04-22-2008, 03:04 AM
  #2633
rcabj's Avatar
Default runtime ??
hi guys. i'm running the ns3 for the its 3rd race few weeks back.
previous 2 races i got a decent runtime between 5'30" - 6 min. but at the recent race it just make the 5 minute markduring the finals i have to come in around 4'30" -4'45". more than that i will run out of fuel .
here's some facts - different track,different fuel ( still 16% like the previos), same engine , same pipe, same plug, same head shim..even the setups for the clutch gap and spring tension r identical, the performance were quite the same..just some gearing changes to suit the track and a bit of fine tuning ofcoz.
.any one can shed me some lightthanks
rcabj is offline
Old 04-22-2008, 01:50 PM
  #2634
Racer Z's Avatar
Originally Posted by dj apolaro
This weekend was the US open and man what a race. I had a good time and some really good racing. I was on top for most of the event but had to settle for second place. Out of the 6 rounds I won 4. Paolo was able to take it with a good run in the cool of the day, getting me by 1 second. Do to the rain we did not get to run the mains. Paolo was also running a Nova based engine. It was evident that the Nova based motors where the motors to beat. Thanks to Novarossi for the great support and awesome products. Till next race.
DJ Apolaro
Your motor was super fast!! Both you and Paolo was like neck and neck the whole weekend. You could tell that the times were reflected by lap traffic only. Great showing for the Novarossi Engines!! I think my 353 was just a little overgeared in 2nd but had enough torque on the bottom to make up the difference luckily. Novarossi is the only way to fly for me!!!
Racer Z is offline
Old 04-22-2008, 06:06 PM
  #2635
hi Guys, just wondering what pipe do u use to match the 353 engine? anyone tried the skyline vr12plus?
backplate is offline
Old 04-23-2008, 12:02 PM
  #2636
2630 with short header. If you need more torgue use medium header.
DJ Apolaro
dj apolaro is offline
Old 04-23-2008, 12:05 PM
  #2637
Different track and different fuel are the reasons. Different fuel can give differece results. Power, run time, life of motor, etc. and tracks are also going to vary.
DJ Apolaro
Old 04-26-2008, 04:52 AM
  #2638
Dreddlox's Avatar
I just ordered a 12Plus 3-SCT tuned and I'm not to familiar with nova based motors and wanted to know what the difference is in the long and short plugs on an engine?
Dreddlox is offline
Old 04-26-2008, 12:40 PM
  #2639
asw7576's Avatar
If I'm not mistaken, The short type is AS IF you are using 1 more shim, thus slightly you get milder compression. The long type is normal compression.
If I'm not mistaken again, some people interpret short vs long glow plug with the retain heat capability they carry. Long body will retain heat longer thus you get hotter engine temp, and vice versa.
Sorry if I'm wrong.
asw7576 is offline
Old 04-26-2008, 09:08 PM
  #2640
Riketsu's Avatar
Trader Rating: 34 (100%+)
Sorry if I'm wrong.
I never heard that AS IF... Could be true, who knows.
Anyways, heres the website where i found some information on how to choose a glowplug for your situation.
http://www.outlawrc.com/glowplugs.htm
Riketsu is offline
