The Speed Passion Thread >
Like Tree57Likes
Old 11-27-2010, 05:14 PM
  #6151
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by rbakker
Hey people,
what is happening with Speed Passion, i have ordered 3 SP13.5 motors V3.0,
all by different webshops all around the world:
1 x in my own country
1 x in the USA
1 x in China
All between 2 to 3 months ago, but they are all out of stock...?
Does anybody know more..?
pm me if u still need the motor...
kschu is offline
  #6152
Trader Rating: 125 (100%+)
You try accessing through Laptop or PC? What software you running. If I remember the 2.0 comes with 205 mod which doesn't have 12-15.
kwiksi is offline
Old 11-27-2010, 09:38 PM
  #6153
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Is the GT2.1 Prostock ESC going to be approved for the ROAR Sportsman ESC list?
SchuMi2 is offline
Old 11-28-2010, 02:03 AM
  #6154
Then i will have 4 on the way...
rbakker is offline
Old 11-28-2010, 01:15 PM
  #6155
irgo's Avatar
Solara tell Speed Passion it's been too long....
source Source
irgo is offline
Old 11-28-2010, 07:29 PM
  #6156
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Hi Guys
Do you have any recommended set up for a 17.5 on a medium size carpet track. I am currently using the 528 program...
I tried my car with a ratio of 7.50 and at max boost and punch but the car did not have any punch nor speed... I tried using a ratio of 6.50 but I did not see any improvements in speed and torque either....
I Also tried a couple of set ups that were listed on the website... But they did not seem to help in my top speed.... Do you guys have any problems in achieving top speed as compared to the tekins?
KELVIN KHNG is offline
Old 11-29-2010, 02:08 AM
  #6157
You try default setup on 528stk?
kwiksi is offline
Old 11-29-2010, 04:12 AM
  #6158
defcone's Avatar
Originally Posted by KELVIN KHNG
Hi Guys
Following Howard Lo's 17.5t on the SP website, my car looked to have the same straight line speed as other tekins. This was on an outdoor asphalt track with a 30m straight.
defcone is offline
Old 11-29-2010, 05:43 AM
  #6159
Hi Guys
528 FW
SP17.5v3 10 degree timing
5.3 FDR
#9/ Max
#12/ 6
#13/ 1
#14/ 1
#15/ 4 adjust down if you need more punch.
Hope this helps
SRW141 is offline
Old 11-29-2010, 06:24 AM
  #6160
Kevin K's Avatar
Trader Rating: 32 (100%+)
Hi Guys
Kelvin....what motor are you using?
Here are the settings that I use with SP 17.5 V3 motor set at 10deg timing advance....and 7.32 ratio at The Track and just about all the Carpet tracks in our area...this doesnt work for all motors with a Duo 2 these adjustments change.
1-3-1-9-3-3-2-1-8-2-9-1-1-5
Kevin K is offline
Old 11-29-2010, 08:41 AM
  #6161
Trader Rating: 17 (100%+)
Originally Posted by Eirik
Have anyone tried the optional rotors, like the silver ones and the super 7's, are they any better?
http://www.kinggolden-rc.com/search.asp?s_key=RM1380
Looking for some more midrange power for my 1/12th scale 4.5t
Thanks,
Eirik Andreassen
for 12th scale MOD motor...try this, you will love it.
RM13806
V3.0 3.5T-8.5T Rotor, Super 7 (Orange ring 13MM rotor with Super 7 - High, RPM, and Long Run Time)
Solara is offline
Old 11-29-2010, 09:24 AM
  #6162
Originally Posted by SaladFork
On the GT-2.0 there are profile settings 12-15 which you can't access via the program box or ESC? How can I access these settings?
Thanks!!
2 way....
(1) LCD programmer box
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
(2) Multi programmer box
http://www.speedpassion.net/us/produ...PESCPB01&c=OPT
Solara is offline
Old 11-29-2010, 10:02 AM
  #6163
Yes....we thought it was DONE already, but we need to contact ROAR again to list the Gt2.1 ProStock and GT2.1 EX on the list...
Solara is offline
Old 11-29-2010, 10:07 AM
  #6164
Hi Guys
Kelvin:
What Kevin said is what we (Chicago Team) used very much @ The Track harbor....you might be using NOVAK Ballistic then it need to be adjusted. We were using SP V3 motor and there is NO WAY it is lacking top speed or low end punch with Kevin's setup...I might not be the one to judge, but this setup was approved by Stegan, King and Sydor...it is the way to go.
Solara is offline
Old 11-29-2010, 02:05 PM
  #6165
Kevin,
I was using the Novak Ballistic 17.5 motor. Any idea what other adjustments do I have to do to my motor or is getting the SP 17.5 V3.0 motor the only option?
