#8251
#8252
Hey all!
Started my build last night. Can someone tell me where I can find the 5 x 7 .2mm shims that people are using in the front axle assembly? Are these plastic or metal shims? I was reading on one site that as long as you line the crush tube up properly, it should not be a problem. Is this not the case?
#8254
He is referring to this:
http://www.amain.com/product_info.ph...ts-74V-3200mAh
Only 155g, normal shorty is in the 210-220g range.
#8258
#8259
Hey all!
http://www.amain.com/product_info.ph...5x7mm-Shim-Set
#8261
Excellent! Thanks for the info! I didn't realize the shims were already in the kit. Seems like there should have been a supplemental instruction sheet or something. Have not checked yet, but maybe my kit does not have them.
A couple more questions...
Page 5 step 2 (Front arms and uprights build) says to use 25215 (M3 locknut, black). I could find no black locknuts in the kit, but there were numerous blue aluminum ones so I used one of those. In fact, 25215 is not even listed in the hardware list. Hope I got it correct!
Also, I remember reading about some people having issues with a particular ball stud pulling out of the plastic, but I cannot remember where this was located on the car and cannot find the thread about it. Can someone refresh my memory?
Thanks!
Thanks!
#8262
Thanks!
Thanks!
#8265
Pro-match shorty is back in stock - 3500mah 90c and only 158g
http://www.promatchracing.com/products.php?cat=38
Anybody have experience with this pack?
