Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 04-10-2014, 09:01 AM
  #8251
Tech Legend
Wild Cherry's Avatar
Originally Posted by splking1
I posted what he suggested in last reply
kool
Will be looking for your report in how those suggestions work.
Did he have his hubs full forward ?
Wild Cherry is offline
Old 04-10-2014, 09:04 AM
  #8252
Originally Posted by Wild Cherry
kool
Yeah his hubs were forward. With 4mm trailing
splking1 is offline
Old 04-10-2014, 09:16 AM
  #8253
mxracer458's Avatar
Trader Rating: 47 (100%+)
Originally Posted by DropPass
Hey all!
Started my build last night. Can someone tell me where I can find the 5 x 7 .2mm shims that people are using in the front axle assembly? Are these plastic or metal shims? I was reading on one site that as long as you line the crush tube up properly, it should not be a problem. Is this not the case?
they are metal,you can't miss them unless they are not in your kit
mxracer458 is offline
Old 04-10-2014, 09:19 AM
  #8254
SilentHunter's Avatar
Originally Posted by Matt Trimmings
He is referring to this:
http://www.amain.com/product_info.ph...ts-74V-3200mAh
Only 155g, normal shorty is in the 210-220g range.
Not to prove you wrong but. Even smc race spec shorties are 151 grams...
SilentHunter is offline
Old 04-10-2014, 09:23 AM
  #8255
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
As listed on the smc site: Race Spec 215g, Factory Spec 203g. The 1s pack is 151 grams, put that in your car and let me know how it is.
Don't worry, you're not proving me wrong.
Matt Trimmings is offline
  #8256
predu's Avatar
smc's site says 215.
predu is offline
Old 04-10-2014, 09:24 AM
  #8257
predu's Avatar
unless you are really looking at 1s batteries??? lol
predu is offline
Old 04-10-2014, 09:38 AM
  #8258
GraphiteChassis's Avatar
So Amain's description is wrong? It sais 155 grams and 7.4v/
GraphiteChassis is offline
Old 04-10-2014, 09:39 AM
  #8259
Hey all!
They are not needed by everyone. Some axles were possibly made too short so that when the front axle was built up it would compress the inner race of the bearings and cause the bearings to fail, this could also be becasue the crush tube was slightly thinner than it should have been. I have zero shims on my axle and have had zero issues, i did however go with avid bearings from the start and have not used the stock ones. If needed you can try these:
http://www.amain.com/product_info.ph...5x7mm-Shim-Set
Old 04-10-2014, 09:41 AM
  #8260
No, look at the mah....it is only a 3200mah where as a standard shorty is in the 4700mah range. Smaller cells = lighter weight.
Old 04-10-2014, 10:04 AM
  #8261
Excellent! Thanks for the info! I didn't realize the shims were already in the kit. Seems like there should have been a supplemental instruction sheet or something. Have not checked yet, but maybe my kit does not have them.
A couple more questions...
Page 5 step 2 (Front arms and uprights build) says to use 25215 (M3 locknut, black). I could find no black locknuts in the kit, but there were numerous blue aluminum ones so I used one of those. In fact, 25215 is not even listed in the hardware list. Hope I got it correct!
Also, I remember reading about some people having issues with a particular ball stud pulling out of the plastic, but I cannot remember where this was located on the car and cannot find the thread about it. Can someone refresh my memory?
Thanks!
DropPass is offline
Old 04-10-2014, 10:08 AM
  #8262
Thanks!
The shims are not included in the kit, he was referring to the crush tubes being included. The kit does come with the blue nuts and not the black so you are fine with that step. The ball stud issue was in the rear hub carrier. Make sure to loctite the ball stud into the blue nut insert, or purchase longer ball studs and use a nut on the back. Also make sure to put loctite on the front axle screw....manual doesnt say to do this.
Old 04-10-2014, 10:24 AM
  #8263
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Just checked Tower Hobbies looks like late April now for the B5M kit
Stanfsu is offline
Old 04-10-2014, 11:36 AM
  #8264
predu's Avatar
That sucks. fortunatly my garage has one nib sitting on the shelf
predu is offline
Old 04-10-2014, 11:51 AM
  #8265
Trader Rating: 23 (100%+)
Pro-match shorty is back in stock - 3500mah 90c and only 158g
http://www.promatchracing.com/products.php?cat=38
Anybody have experience with this pack?
flybyublue is offline
