Trinity G4 - Team Magic G4 E-Type
#1786
g4 steering servo
hey guys, i'm new to the forum. i have a g4 and i am in need of some help. tried a jr servo for steering, no way it was fitting. saw a post on here from rcnutz about using a futaba s9550. just got it today and on the back of the box it says "ni-cd use only" i was going to use the trinity rc5308 receiver pack. my question is will it work? from what i've read on this forum you guys seem to really like these cars. i also have a team magic spring kit, any ideas on a set-up? thanks for any kind of help.
#1787
Hi owens,
Welcome to the club,
I also haven't had my car that long, however I have used the 9550 on my RR evo and have had no problems running with a 800 mah NimH pack. Its a great little servo, its just the right size cos I can fit a fail safe behind it.
Setup wise:
My track is small and tight, and I run the following:
Stock springs
Front:
Camber: +2
Toe-Out: + 1
Ride Height: 5
Diff - 100,000 Oil
Rear
Camber: +2
Toe-in: +1
Right Height: 6
Diff - 30,000 Oil
Hope that helps
Setup wise:
Stock springs
Front:
Camber: +2
Toe-Out: + 1
Ride Height: 5
Diff - 100,000 Oil
Rear
Camber: +2
Toe-in: +1
Right Height: 6
Diff - 30,000 Oil
Hope that helps
#1788
Servo Saver UGH!!!!
After a long trial and tribulation why my clutch was not working properly(loose nut behind the wheel), my servo saver cracks. Why did TM make a K factory aluminum servo saver, if they only wanted to go half way. They should have made both peices in aluminum. Now I have to get the plastic upper piece. Where is the updated steering when you need it?
I can not give a update on how the car works because I only burned half a tank of gas, and was at the track for 5 hrs. What a waste. Sorry to sound so negative, I am just a little discouraged, but I will fix it, stronger and better... Till next time.
#1789
Re: Servo Saver UGH!!!!
#1790
it's a pain in the ass..when such things happen ...well take it in stride.....at least like what i did always..its hard to sit at the track side repairing our cars when the rest of the guys are on track racing ard...give them a chance to perform!.....
#1792
owens, whats up, and i hope you enjoy our "discussion"
vr6vroom, sorry to hear that
rc_alan, do you have any more updates on the fix from TM ???
Later, & go pistons
Later, & go pistons
#1793
bballer... I contacted Nick ko from TM on Monday about the steering system update... He reply that they are still working on it, but are very close to having something ready in the near future... I would like to see them get it right then to rush something that's not ready... Haven't sold my G4 yet, just waiting to see what comes down from TM..
RC_Alan
RC_Alan
#1795
Vr6vroom - I got a couple extra servo savers thinking I might need them, but have never had a problem with the steering. So if you want them, drop me an email... Just wondering, but how did you break that without hitting anything?
On another note, I just wanna say how dialed the G4 is. It looks pimp, is very easy to drive fast, and I have never broken one part on it.
#1796
All I can say is that when the steering update is available, Nick needs to make them readily available to the people in here, and elsewhere, who have speerheaded the entire campaign to get the steering improved.
#1797
Amen
#1798
Confusion
#1799
g4 wiring
bballer and ttektek thanks for the welcome. anybody have any pics they can post of there cars? looking for some wiring solutions, i would like the car to look as neat as possiable.
this is the equipment i have:
g4 pro
rossi black pixi
team magic pipe
jr r200 receiver
jr power switch w/charge lead
jr throttle servo
futaba s9550 steering servo
rc5308 recevier pack
ofna fail safe
g4 pro
rossi black pixi
team magic pipe
jr r200 receiver
jr throttle servo
ofna fail safe
#1800
