RDLogics Mongoose
#1966
loose rear
Fellas can someone help me???? i have a stock set-up with a TZ18....i have no rear grip...every time i hit the throttle the car spins out....i have lifted my shocks straight up....and have tried softer springs....but nothing works.. do u guys have a cure???? im at 5 deg ont the camber and 2 deg on the tow...an 5mm on the ride height.....is it posible that i might have too much motor???? Please help?????
#1969
Motorman: It aren't the screws who are grinding in the two speed bell, is is the cam on wich the shoes are attached. The cam grinded about 0.5/1.0MM into the bell and now hits the bearing, wich I think will stop the grinding.
But anyway thanks for the tip about shorten the screws, I looked at it and the screws are almost hitting the two speed bell, so I will shorten them anyway.
Do you have a good starting point for the amount of turns the two speed screws have to be screwed in? or is the strarting point stated in the manual a good one?
Thanks in advance.
Thanks in advance.
#1970
Thanks in advance.
Thanks in advance.
#1971
Ok, thanks
#1972
parts
Sfelish, Good job Sam, tnx. pls ck your PM....!
#1974
clutch spring
I would go for the orange spring. Tighten it down so as 1 to 2 threads are showing. (Around 0.3 to 0.6mm)
90% of the time the orange spring is good. On high grip surfaces and depending what motor you have, the yellow one, set flush to 0.3mm tension will be good.
Hope this helps.
Tony
Hope this helps.
Tony
#1976
Anyone have any setup sheets for the Mongoose? Looking for a few ashphalt set ups.
Thanks.
Thanks.
#1979
clutch spring
rcrevoloution
It really depends on the track your on....... if it is high bite, if it really has alot of grip, then you could be ok with that spring. Try starting out with it set flush. Then try tightening it, 1/4 turn at a time and see if it works better, see if you like it better
hope it works
hope it works
