Old 04-12-2006, 01:08 AM   #1966
bigbank66's Avatar
Default loose rear
Fellas can someone help me???? i have a stock set-up with a TZ18....i have no rear grip...every time i hit the throttle the car spins out....i have lifted my shocks straight up....and have tried softer springs....but nothing works.. do u guys have a cure???? im at 5 deg ont the camber and 2 deg on the tow...an 5mm on the ride height.....is it posible that i might have too much motor???? Please help?????
bigbank66 is offline   Reply With Quote
Old 04-12-2006, 02:34 AM   #1967
Motorman's Avatar
Thybaut you have the 2 speed screws to deep. they are comming out the other side and gouging the two speed bell. On the mongoose cars we used to shorten the 2 speed screws 3 threads with a file and reinstall them so it does not do that.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-12-2006, 02:35 AM   #1968
Motorman's Avatar
big
make sure your belts are not missing teeth stopping the front from driving properly. then check the car to see if it is tweeked. lay the rear shocks all the way down.
Old 04-12-2006, 07:57 AM   #1969
Thybaut's Avatar
Motorman: It aren't the screws who are grinding in the two speed bell, is is the cam on wich the shoes are attached. The cam grinded about 0.5/1.0MM into the bell and now hits the bearing, wich I think will stop the grinding.
But anyway thanks for the tip about shorten the screws, I looked at it and the screws are almost hitting the two speed bell, so I will shorten them anyway.
Do you have a good starting point for the amount of turns the two speed screws have to be screwed in? or is the strarting point stated in the manual a good one?
Thanks in advance.
Serpent 733 TE | RB Touring 9, Novarossi N12T1 | Sav÷x SC-1257TG | Ko Propo EX-10 EURUS
Thybaut is offline   Reply With Quote
Old 04-13-2006, 10:10 AM   #1970
itchy b's Avatar
Thanks in advance.
when i first ran my g4 i had the same problem of not shifting with the stock setting , found loosening scews 2 -2.5 turns out got the shift woking pretty close to right. hope that helps you .
itchy b is offline   Reply With Quote
Old 04-14-2006, 03:48 AM   #1971
Thybaut's Avatar
Ok, thanks
Old 04-18-2006, 09:35 AM   #1972
Default parts
Sfelish, Good job Sam, tnx. pls ck your PM....!
EcZahst1 is offline   Reply With Quote
Old 04-18-2006, 11:55 AM   #1973
rcrevolution's Avatar
Send a message via AIM to rcrevolution
guys, which color is the best for a dry surface, medium to high grip?
i took the red spring out of the mongoose and put a mugen hard spring in it, but i was wonder if the orange or neon green spring was any better for my surface.
rcrevolution is offline   Reply With Quote
Old 04-18-2006, 04:03 PM   #1974
British Menace's Avatar
Default clutch spring
I would go for the orange spring. Tighten it down so as 1 to 2 threads are showing. (Around 0.3 to 0.6mm)
90% of the time the orange spring is good. On high grip surfaces and depending what motor you have, the yellow one, set flush to 0.3mm tension will be good.
Hope this helps.
Tony
British Menace is offline   Reply With Quote
Old 04-18-2006, 07:30 PM   #1975
well i have the mugen silver spring right now and its their super hard spring which is equal to our yellow spring so am i ok?
and if im running that stiff on yellow whwere should the nut be? flush or tighter then flush?
Old 04-18-2006, 09:17 PM   #1976
Dreddlox's Avatar
Anyone have any setup sheets for the Mongoose? Looking for a few ashphalt set ups.
Thanks.
Dreddlox is offline   Reply With Quote
Old 04-19-2006, 12:13 AM   #1977
Motorman's Avatar
g4s conversion kits are finally available
Old 04-19-2006, 01:51 AM   #1978
Car Breaker's Avatar
availeble from you or TM? taht make huge differences
how much is the approximate price in US?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 04-19-2006, 05:16 AM   #1979
rcrevoloution
It really depends on the track your on....... if it is high bite, if it really has alot of grip, then you could be ok with that spring. Try starting out with it set flush. Then try tightening it, 1/4 turn at a time and see if it works better, see if you like it better
hope it works
Old 04-19-2006, 08:48 AM   #1980
Motorman's Avatar
from us! we finally got them
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
