Exhaust Extensions?? >
Old 07-19-2004, 07:13 PM
Default Exhaust Extensions??
I have the dodge stratus body and the body is so wide that the exhaust pipe tip doesnt come out of the car. It makes such a mess. Is there anything out there that I can add on to the tip to make it come out of the car?? Thanks for the help.
R/Cstratus48 is offline
Old 07-20-2004, 02:27 AM
tkhoo's Avatar
Trader Rating: 45 (98%+)
use tubing.............
tkhoo is offline
Old 07-20-2004, 03:28 AM
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
what kind of heat-resistant tubing?
got pic?
where to find it?
mop
mop_iko is offline
Old 07-20-2004, 06:24 AM
BrainTeased's Avatar
got pic?
where to find it?
mop
all LHS have em!
BrainTeased is offline
Old 07-20-2004, 10:00 AM
macnkitty2002's Avatar
this should work. heat resistant exhaust deflectors
http://www2.towerhobbies.com/cgi-bin...&I=LXL378&P=ML
macnkitty2002 is offline
Old 07-20-2004, 10:10 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
got pic?
where to find it?
mop
Marcos.J is offline
Old 07-20-2004, 04:02 PM
PSI Racing's Avatar
Is there any performance lost when using an extension.
On my 1/8, the exhaust is no where near the body.
PSI Racing is offline
Old 07-20-2004, 04:06 PM
theRED5's Avatar
YES, don't worry if the pipe doesn't get all the way to the body, these things are NOT good for your engine.
theRED5 is offline
Old 07-20-2004, 04:22 PM
PSI Racing's Avatar
Alright.
I'm glad I never used one on my car then.
I usually get a rag and clean off the inside of the body.
Old 07-20-2004, 05:09 PM
tkhoo's Avatar
got pic?
where to find it?
mop
Mop, u work in factory?? If yes, than u can use air tubing. I not sure is 10mm or 8mm.
tkhoo is offline
Old 07-20-2004, 05:11 PM
Hey, theRED5, why arent they good for the car? i use them on all of my nitro cars and dont see any performance loss. maybe the one that you are using is too small, restricting the airflow maybe? the only difference i notice with them is a muffling of the exhaust sounds, thats it!
Old 07-20-2004, 07:29 PM
ctardi's Avatar
i do beleive it affects high end torque, but im not too sure
ctardi is offline
Old 07-21-2004, 01:24 AM
mop_iko's Avatar
Default STINGER length issue....
last time we have this stinger lenght and performance THREAD ...
so maybe this TUBING will have implication.
performance implication and also racing regulation implication.
mop
mop_iko is offline
Old 07-21-2004, 08:29 AM
i still dont think that it cuts down on performance if you use the right size of exhaust tubing. plus i meant to tell you that you should cut the tubing down to where it exits the body. it should not come out of the body more than 1 inch.
Old 07-21-2004, 09:08 AM
orangbaligila's Avatar
It will rob performance on the top range,.. like I've mentioned in the other thread,... longer stinger (the deflector counts as a stinger btw) will give you more torque (lower engine speed power) up to a certain level, then starts robbing power out too..
my tip: leave the exhaust without them for racing, some dirt and other mess would worth the trophy.. for daily use, it's all up to you
orangbaligila is offline
