Serpent 710
Old 04-23-2004, 04:02 AM
  #8761
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Originally posted by BaxterC
So you can get KO servos and sell them for less than $95???
Will you be an online store?
Will you be able to ship to South Africa?
Will you have Bodies? And paints, and be able to process credit cards?
And will you be able to sell... Serpent products?
I'm going to work on Serpent next week.
The KO servos are hard to sell for that cheap.
I would only be making a 20% profit if I sell it at that price.
The hard thing about selling KO in the states is other countries get a lower cost on them.
I live about 1/2 an hour from Proline/Protoform.
I haven't set anything up with them yet.
Getting more manufactures on my list is one reason for going to RCX this weekend.
I want to see what's going to be coming out.
Yes, I will be doing internet sales and I will be able to process credit cards as soon as my site is up.
I'll see about shipping to South Africa.
I don't know what shipping would be like.
PSI Racing is offline
Old 04-23-2004, 04:13 AM
  #8762
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
If you can do serpent and ship to SA and be reasonable, You have a customer.
BaxterC is offline
Old 04-23-2004, 04:15 AM
  #8763
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Alright.
Give me about a month to get my site up.
Do you guys have paypal there?
Old 04-23-2004, 04:21 AM
  #8764
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Alright.
No, we dont, I wish as it would make life easier, we have good old visa and mastercard only. I may start looking for some parts for my 710, I dont order so often, but I order big when I do. RC mushroom are smiling... over $1000 in one shot.
BaxterC is offline
Old 04-23-2004, 04:28 AM
  #8765
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
You can transfer money onto a paypal account using your credit card.
Cheers, Mark.
markp27 is offline
Old 04-23-2004, 04:30 AM
  #8766
PSI Racing's Avatar
If anyone has any brands they want me to pull in, let me know.
Old 04-23-2004, 04:32 AM
  #8767
BaxterC's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Cheers, Mark.
AH, that would be great... Thank you Mr Mark, Where have you been?
BaxterC is offline
Old 04-23-2004, 04:39 AM
  #8768
KevinS's Avatar
Originally posted by Pyramid
A bit longer on total length and also from pin to end of spur.. 6mm (inner diameter) precision shims would do the job find to remove a little sloops on the first spur gear. But the weight saving is much more important since it TURNS...
I received the parts today and found no problems fitting the 2-speed shaft and the same goes for the upper bumper plate.
There is one problem with the 3racing upper bumperplate though: They forgot we like to fit an AMBrc DP transponder underneat it but the aluminum part that holds the up-stop setscrews prevents this. So I had to mount it on top...
Also got 2 sets of 808220 "PRO"driveshafts which are.... black
And about rotating mass off the Ti shafts:
The main difference is that the middle and 2-speed shaft together take about 15g off the total weight of the car. The difference in rotation resistance is sooo very small, nobody will notice it.
I think Julius mentioned this before.
KevinS is offline
Old 04-23-2004, 04:50 AM
  #8769
BaxterC's Avatar
You are right, he did.
If the shafts of the hudy drivers are black, then I am sure the dogbones should also be, or am I wrong?
Check it out, I am an Addict... this I must admit, is true, I am.
BaxterC is offline
Old 04-23-2004, 05:14 AM
  #8770
KevinS's Avatar
I have hudy springsteel wheelaxles and dogbones for my 705 too, which are all brown. But I sent an e-mail to Serpent benelux to be sure... Will get back on it as soon as I receive a reply.
KevinS is offline
Old 04-23-2004, 05:30 AM
  #8771
Default Re: Re: Roll Center
Oh yes, I think the roll axis play more important role for that matter.
I think there is confusion about the question that was originally asked, and my reply.
Here is the original question:
What I`m interested in, what is the benefit for having higher RC but with the lower arm mounted far more toward up from the bottom of chassis. I mean, when the lower arm is now mounted on its highest point, the weight of the rear (CG?) is somehow lower. Does it then generate more tracktion??
When I responded, I meant that the position of the lower arm has no effect on the CG of the car, but will of course have an effect on the RC of the car.
GlennCauley is offline
Old 04-23-2004, 05:34 AM
  #8772
Default 808220 dogbones
Oh, about the 808220 spring steel dogbones, I was incorrect.
They ARE shorter in overall length than the original S710 dogbones by a little bit less than 1mm.
The pins are also closer together by approx. 0.5mm.
Hmmm... my shoe tastes terrible this morning...
Old 04-23-2004, 05:48 AM
  #8773
BaxterC's Avatar
Default Re: 808220 dogbones
I am sure it would anytime of the day... just make sure you never stood in dog doodle...
http://www.ashfordhobby.com/PDF%20files/SerPrice.pdf
This is the FULL serpent line at ashfordhobby.
I am sure that the bogbones were brown, but there is more than one person conplaining that they are black. maybe they changed the colour?
BaxterC is offline
Old 04-23-2004, 07:40 AM
  #8774
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Originally posted by InitialD
Ahah, while being busy at the podiums, you're busy somewhere else ! Congrats ! Don't forget to pass the cigars around.
thanks I will
Marcos.J is offline
Old 04-23-2004, 08:30 AM
  #8775
Blue Sky's Avatar
I got a pair of black ones too. I called Serpent USA yesterday and they knew about the problem. They said it's some packaging error. The guy dealing with this issue is at RCX this weekend, and they'll get back to me next week.
Blue Sky is offline
