Speed Passion F1 car - The SP1
#1426
Still no local stock.
Now, it is over 12 weeks with a broken car.
Good on you, great customer service. "NOT"
I ordered other parts for some of my other cars from my local distributor and he was prompt and reasonable. So I don't think I can lay the blame on him.
I can only say the it's an SP problem. I get stuff in 10-20 days from the US with cheap shipping so, it's not a shipping issue.
I just want to drive my car, is that such a big ask.
#1428
looking for opinions for a F1 servo.
will this be enough torque im thinking for a f1 it be overkill but not by much.
https://www.greathobbies.com/product...id=SAVSC1251MG
#1429
very good servo , i use it in my Xray X1 for more than 8 month. flawless
#1430
What is your budget ? The Savox is ok for the money. I recently put a KO brushless servo in my car, and honestly I can understand the importance of investing in good servos
#1431
I got SP1 with a used hitec worked ok. But doesn't centre anymore and im not the best driver i still hit the board alot but try to avoid bumping or tapping them. Not yet use to driving a F1 yet was only going to drive it this season and get a better handle on it.
#1432
Hi All,
I know a few people here has done the Exotek top arm conversion for the SP1, just wondering if you can provide the link measurements or would they be the same as what's on the F104.
Also have you guys found an improvement overstock?
Thanks.
Thanks.
#1433
Hi guys, does anyone have a list of the the spring rates available for the front of this car? I can see on the setup sheet that they are listed as Soft, Medium, Hard but what are the NN/mm or Lbs rating of the springs? I want to try the new Ride F1 front springs but would like to understand how these springs compare to the SP ones stiffness wise before I do. Many thanks!
#1434
Transverse Lipo Chassis
Having tested and refined my aluminium prototype chassis, I've had the parts I've designed made in carbonfibre by Fibre-lyte. They arrived yesterday, the quality is superb, and I've completed the build today. It uses shortened Schumacher superstox side dampers, & gets rid of the separate plate for mounting the front suspension.
#1435
#1436
#1440
Well, I pulled the trigger and ordered the Tresrey SP-1. I also ordered a set of front and rear wheels, a 21.5T motor, and a couple of extra containers of grease (general and ball diff). After tax, with the discount, it came to just over $200. I have an ESC, servo and receiver to throw in. All I need now is a body. I was going to order one from speedpowerrc too, but then I thought I'd order one on Ebay that models a current car. I'm eyeing either the McLaren Honda or the Haas. I'd prefer to honor Haas but the paint scheme is more difficult.
