Like Tree16Likes
Serpent S411
Old 09-30-2013, 07:57 AM
  #5911
gearhead_22's Avatar
Originally Posted by Tshabalala
Im about to start a serpent s411 project and would like to get some recommendations for a brushless motor and esc. What would you guys recommend?
I all depends on your money. you can get a high end speedo like lrp-orca-tekin, or a low end like novak-hobbywing-speed passion. and all the motors are about the same price. I my self am running a LRP flow and a LRP X20 17.5.
gearhead_22 is offline
Old 09-30-2013, 12:51 PM
  #5912
yeah i want a high end one
Tshabalala is offline
Old 10-01-2013, 06:17 PM
  #5913
jdawg81's Avatar
Default Where can I get longer body posts?
Does anyone know if there are longer body posts available for the S411 ERYX? The ones that came with the kit are too short and the HPI 1966 Ford Mustang GT body I'm trying to mount on my car for VTA sits too low.
I also have a problem with installing a servo saver for a Savox SC-1251MG that won't hit the servo mounting bracket when trying to install it. It seems like when the servo is mounted it sits too far back and if I install the servo saver there's not room for it to move left or right. I'm not sure if I'm explaining this right but hopefully you guys will understand what I mean. So what is everyone using for a servo saver?
jdawg81 is offline
Old 10-01-2013, 10:28 PM
  #5914
I use a xray servo saver.
I remember I had to trim it a little so that I could get it to fit, but it works good.
gerg is offline
Old 10-02-2013, 12:21 AM
  #5915
nathan c.'s Avatar
I use a 1mm shim between the servosaver and servo, and with a little bit of trimming on the sides of the servo saver it allows the servo to move freely.
Are you using the right servo saver insert that matches the number of teeth on the servo ?
nathan c. is offline
Old 10-02-2013, 07:21 PM
  #5916
1shnot's Avatar
what is the biggest spur would it fit? trying to get 3.9fdr for 17.5 blinky... looking to get tc6 106 with 54 pinion, anyone tried this combo? would I be able to reach motor ?
thanks
1shnot is offline
Old 10-02-2013, 08:14 PM
  #5917
ICEBERG's Avatar
thanks
Highest you can go on 106 is 50 pinion. 54 wont fit. I have a 100 with 50 with 4.0fdr. If you want 3.9fdr go with 92 spur with 47 pinion. Or you can do 90 with 46 pinion.
cheers,
ICEBERG is offline
Old 10-03-2013, 08:57 PM
  #5918
tiago890's Avatar
Took the s411 te out on the carpet for the first time this past Sunday, car felt good, thanks to Johnny Wishbone for sending me his setup a while back, was a good starting point. Now just have to work out the final little kinks and practice a bit more and should be good to go for this winters race season.
tiago890 is offline
Old 10-04-2013, 04:23 PM
  #5919
ICEBERG's Avatar
Hey guy's..Got my savox 1252 servo installed with the X-Ray servo saver. Problem i ran into was that the servo saver was rubbing the surface of the s411TE chassis. So i got some 2mm washers to raise the servo posts to clear the bottom chassis. Would raising the servo a little cause any flex or other issues with handling?
I thought about trimming the bottom of the servo saver arm, but it was still going to rub.. What did you guy's do to solve this issue?
thanks,
ICEBERG is offline
Old 10-04-2013, 04:45 PM
  #5920
thanks,
when I was running the TE car I used double sided tape under the servo and did not use the out side mount and it worked just fine. you can also get the updated servo mount and put it on your TE.
Old 10-04-2013, 05:00 PM
  #5921
ICEBERG's Avatar
This is what the setup looks like now. I don't like using double sided tapes on servos (just my preference). I might invest in the new servo mount though.. But, want to see how this works first..
ICEBERG is offline
Old 10-04-2013, 10:29 PM
  #5922
When I was running the Xray servosaver on the TE servo mount I took my dremmel and did a modification in the "extension plate" under the servosaver. You needed maybe one or two mm dremmeled out.
Linguster is offline
Old 10-04-2013, 10:40 PM
  #5923
Also want to thank "Johnny Wishbone" for his setup and the answering all my questions. Finally both Mod car and Super Stock are ready and "tucked in" in the carry on bag ready to fly to IIC race in Vegas. See you there Gary.
Old 10-05-2013, 01:17 PM
  #5924
ICEBERG's Avatar
Just took the dremmel to it and took of couple mm off from under the servosaver and it is still rubbing. Looks like X-ray servosaver won't work with the TE.
ICEBERG is offline
Old 10-05-2013, 02:32 PM
  #5925
I went to look in my boxes to find the dremelled plate to take a photo. I guess it went with one of the cars that I have sold. I took a one of the tools in the box that are 3 mm wide and put a pencil mark in the plate and dremelled a 4mm wide and 2 mm deep concave mark in the plate. I did not need to raise the servo mount in the way you have done.
