Like Tree9Likes
Old 09-15-2011, 06:49 PM
  #20191
R.Bryant's Avatar
Trader Rating: 16 (100%+)
Originally Posted by RC*PHREAK
yes. i'll be there for you to smoke me.
Oh come on now bring your scale. See you there
R.Bryant is offline
Old 09-15-2011, 06:54 PM
  #20192
JASON671's Avatar
Trader Rating: 54 (97%+)
anyone know the size of the 4 screws that screw the ring gear to the diff housing? also what are some things to look out for with this truck? any must have upgrades or mods?
JASON671 is offline
Old 09-15-2011, 06:56 PM
  #20193
Asharus's Avatar
Trader Rating: 42 (100%+)
From the first page, you can use longer screws
Diff housing screw size (for people who have stripped the screws and want another option) Four screws - 2.5mm 45 pitch 10mm. HPI has some screws that work part# Z449 , they are M2.5x12mm 2mm longer than stock but the holes are deep enough in the diff housings.
Asharus is offline
Old 09-15-2011, 07:09 PM
  #20194
BmainStar's Avatar
Lots of info here on hop ups if you dig Deeper!The only must have is a rear shock tower either an extra or go Carbon .Other than that you can race it box stock!!
BmainStar is offline
Old 09-15-2011, 07:13 PM
  #20195
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Brushless420
Funny I called them yesterday and the person I spoke with had no idea about any change made to the part or any revision period. He said he didnt think they were doing anything about the issue and didnt think there was an issue. Claimed he would call me back once he asked "someone". Never received a call as of yet.
I called Tuesday, after being on hold 2hrs and 11 mins someone finially picked. (Had the celly on speaker phone while I worked on the PC) The guy I spoke to knew nothing of the change and but said he's send me the rears but I'd have to wait on the fronts. Thats a start anyway, Thanks HH !
Bondonutz is offline
Old 09-15-2011, 07:19 PM
  #20196
Originally Posted by Briguy
The black springs .
I guess what I was looking for is what rate are the black springs.
Ben Burtle is offline
Old 09-15-2011, 07:21 PM
  #20197
Originally Posted by Casper
Black is the middle spring. Gold is harder, silver is softer in the Ten springs.
Thank you
Old 09-15-2011, 07:23 PM
  #20198
Briguy's Avatar
Trader Rating: 125 (100%+)
Fronts are 3.9 and rears are 3.3
Briguy is offline
Old 09-15-2011, 07:30 PM
  #20199
ChefDementia's Avatar
Trader Rating: 19 (100%+)
There is only one complaint that I have for the TLR tuning kit, No TLR stickers?
ChefDementia is offline
Old 09-15-2011, 08:09 PM
  #20200
timannnn6's Avatar
Trader Rating: 140 (100%+)
REFUND!!! SEND IT BACK!!! LOL
timannnn6 is offline
Old 09-15-2011, 08:23 PM
  #20201
Feint Motion's Avatar
Trader Rating: 24 (96%+)
same with the chassis!
On a serious note, I did return my TLR chassis. I found the Bump chassis a bit more flexible.
Feint Motion is offline
Old 09-15-2011, 08:53 PM
  #20202
slash24's Avatar
what is the best chassis out there for the scte? as far as i can tell there is three correct? one from losi, another aluminum one from im not sure who... and a graphite one?
slash24 is offline
Old 09-15-2011, 08:54 PM
  #20203
losi_racer's Avatar
Trader Rating: 25 (100%+)
imho opinion losi. if you want setup advice run what the pros run, they are not going to run a bad product.
losi_racer is offline
Old 09-15-2011, 08:56 PM
  #20204
SaladFork's Avatar
SNR - Carbon Fiber
BCE - Aluminum
Tim Bump - Aluminum
Losi TLR Chassis - Aluminum
The best IMO all of them, these are great options. I run the BCE and love it.
SaladFork is offline
Old 09-15-2011, 09:20 PM
  #20205
Trader Rating: 13 (100%+)
I guess I am curious what you all are referencing...if it is the updated set screwed coupler, that is a part update. Soemthing you buy once the old one wears out. Not soemthing you call CS about. The original works great, these just work better. I have informed CS that this is NOT a CS issue.
With the originals, if you grease them properly and space them out on the shaft far enough for them not to bind as recommended here numerous times, they last for 6 months or more. Its the moment they bind when rotating the drive shaft at that front angle that you have a problem and that comes from pushing it too far onto the pinion shaft.
Also, if you spit the pin through the plastic, you can simply dremel a new notch for the set screw in the plastic and rotate it and good as new.
hacker07 is offline
