HoBao Hyper 9E thread
#1216
Set up the buggy to be as light as possible if your having issues w/ chasis flex. I think the car was designed to flex some because it makes it more forgiving on rough u.s. tracks. Perhaps run a neu 1509 2y w/ a 6s 2650 lipo & a MMpro. That would shave about a pound off of alot of the setups you guys mentioned right here & get your 10 minutes of run time.
#1217
the chassis of the hyper 9 depends on all parts to withstand the shocks, I remove the battery box. The chassis lost its rigidity. If only a small building partner you think you have problems, but if you decide to remove it must add a piece for greater rigidity greetings from Argentina and forgive my English
#1218
I am a big believer in higher voltage being better for less loss and all, but the lower KV motors need to be bigger to keep the resistance down. At OCRC most of the fastest guys are now down to running just 3S. For now I am sticking to the 4S setup. I am HEAVY, but it gives me a huge range of gearing options with heat and run time not being aan issue.
#1219
(Please see picture of my H9e)
As for the Elite RC Mount, that does not increase or reduce the lateral or front/rear stiffness, but it does capture your center diff from excess play under torque.
(Look at the picture of Jeremy Kortz battery box)
#1220
I am looking for a new way to run electric after a strong MT season last year. I am wanting to stick with electric after my big investment in the equipment to run the MT. I am looking at two vehicles and the 9e is on the top of my list. My question is what seems to be the weakest parts of the car. I am wanting a good quality car that does not cost me a arm and leg to get the weak points out. The only other car I have even added to my list is the AE RC8BE, but to build that it puts me right at 600 in the car before I get to the rest of the equipment. Anyway before last season I raced Jammin's with very little issues, so going back with a OFNA product. Hopefully this one is the same way.
David "Tiny" Johnson
#1221
-Revised front A arms
-Rear upper link plastic ends
-Out drive cups Part# 87021
-White or Blue Spring Set
-Front CNC Aluminum Chassis Brace
-Wing Mount & Wing
-Either plastic shock parts or CNC Aluminum Shock Caps
-Elite RC Motor Mount if still available @ www.elitercd.com
-Lighter Sway Bars
Some of these parts are subjective depending on what size and surface track(s) you race at but these parts will find use asap and fix any premature parts that wear quickly or may break.
#1222
My H9e has been rock solid after the following mods :
- Hyper 8.5 upper A arms cut to fit
- Updated front A arms -ticker around hinge pin -original cracked open on first day out..noticed it during cleaning
- Front CNC Alu chassis brace - also found broken during cleaning after first day out..
- White springs set
and to add to ST-E guy's list
- Tekno mudguard to keep dirt out
- gradually cutting more and more out of the battery box as my ProMatch 4S are a real tight fit.
After running about every other week end since August, wear and tear items now includes center drive shaft, front diff case input drive cup (part #87021 to order from..Taiwan -special-rc on ebay- ) and front CVA dog bones.
- White springs set
#1223
- White springs set
- White springs set
Happy racing!!
#1224
just ran my yesturday for the first time...love it! very 'pivot down the middle' balance this car has, perfect for tight clay tracks.
tekin 2650 combo
turnigy 35c 3s 5000
airtronics 94780 steering
and plan to get some jconcept gold compound barcodes.
tekin 2650 combo
turnigy 35c 3s 5000
#1225
hi guys,took my 9e out today,it has a castle 2200 combo,was going great untill smoke started coming from the esc,then a flame,luckily put it out,only damage was esc,any ideas what could cause this?
#1227
the gearing on my 9e is 15t pinion and the esc is sat on the chassis,emailed castle yesterday but not heard anything yet,
#1228
That doesn't sound too high depending on the track. I have been told that putting the ESC on the chassis is too hard on them but mine is sitting under an SNR mount on four layers of silicone servo tape. I saw some dense foam insulating tape the other day at home depot and was thinking of trying it as a cussion
#1229
Registered User
40 buck free priority mail shipping.
#1230
my esc does sit on 2 sticky foam pads on the chassis,no vibrations at all,not happy at all.
