Awesomatix EP Touring Car (A700 Shaft Drive)
#7366
Awesome job to Steven for putting it in the stock TC show with that trainwreck of a box of parts that I gave him! Just imagine if he actually drove it before that Friday?
She started life as an original kit over 2 years ago and has some good mojo for sure.
That shirt seems to suit him well!
Mike Slaughter
Mike Slaughter
#7371
Anyone know what the part number is for the special grub screw used in the GD2? This is the one with the end that seals inside the outdrive shaft. I've managed to lose two of them refilling diffs.
Edit: Never mind, found it. In case anyone is looking it is SS3X4-1 M3x4 DIN915 Screw x 2
#7372
Mike Slaughter
Mike Slaughter
It's really just evidence of how well this car works in stock. I pieced it together, guessed at a setup, made a few tweaks over the weekend and by Sunday I had a race car. Hands down the best TC I've driven on rubber tires. Now I'm just looking forward to indoor champs 😁.
#7376
with a topdeck on an evo is there a need for am50?
#7378
In the description the SD2 is said to "give the feel of a belt". Does this mean when coming on power out of the corner you get a little more initial pull on the front spool and the car is a little less inclined to step out with the rear wheels if your on the power a little fast?
#7379
The gaps to either collar from the center FFG support is not at play with the top deck
Should feel more like a belt car.
Truth be told... I'm a bit skeptical on this myself.
