Polycarbonate paint choice
I am new to painting but have a few bodies I will need to paint in the near future and would like to see what paint is preferred. I was looking at proline and duratrax not sure which one is better.
any suggestions are appreciated
Keep in mind that Testors discontinued the Pactra line last year. There may be some outlets that still have stock, but whatever they have, that will probably be it.
Anyway, that being said, if you’re looking at spray painting from a can, the aforementioned Tamiya lexan, or Duratrax lines are likely the way to go. If you are interested in airbrushing, your options open up a bit. There’s the Pro-Line paints, and there’s also Createx paints. Both are acrylics, as opposed to the lacquers that spray can paints usually are.
Thank you all for you input
For Spray Cans: I've tried everything else and will now only use Tamiya PS and Spaz Stix (https://www.hobbyrecreationproducts.com/pages/spazstix)
I like Tamiya PS paints because the nozzle they use on their cans makes the paint come out in a finer mist. This makes it easier to apply multiple lighter coats.
When using rattle paint cans....
- don't hold the can too close to the body when painting.
- light coats are better
- you can use a hair dryer to speed up the drying process between coats (make sure to check any paint masking tape after using the hair dryer)
- decals can make any paint scheme look better
Regardless of which paint you choose, make sure to wash the body out with dish soap/plenty of water and completely dry before painting.
Painting
Proline is made by Createx and there is another popular named one (cant remember ) that is marketed like Proline but is also Createx. If you plan on only a few here or there then I suggest the Tamiya polycarbonate rattle cans.. I posted one I did with it and Testors model paint (highlights with a brush) it takes longer with the Tamiya paint but if you dont already have an airbrush setup then its the cheaper way to go.. You can also use a combination of the Tamiya and Createx (airbrush highlights) .. So theres several ways of skinning that cat.. Mine didnt turn out too bad .. Wanted to see the cheapest way of doing one custom like.. Good luck
Painting
Tamiya Spray cans and a little Testors playing..
My hands aren't as steady as they once were..
Another vote for Tamiya PS rattle cans. If I did more than a couple bodies a year, I'd invest in an airbrush setup.
Testors
Testors also makes Acrylic paints. Picked up a 10 piece box of the major colors at Hobby Lobby for 13.99.. Washes up with water and it's tough to get off to almost impossible when dried on the Polycarbonate bodies..
