Roche Rapide F1-2016 >
Like Tree8Likes
Old 09-23-2017, 11:12 PM
  #286
Trader Rating: 30 (100%+)
Hello, I just got 2016 version. What would be a good starting point gearing wise for 25.5? CRC black carpet, Yokomo tire F/R, med size track, Speedzone 25.5 motor. I've looked at setup sheets and in this forum and can't find 25.5 gearing, plenty of 21.5, thanks
Reck83 is offline
Old 09-24-2017, 06:54 AM
  #287
Dobbs's Avatar
Trader Rating: 31 (100%+)
3.0 - 3.3 start at 3 and go from there. I run a 3.13 fdr turning a 100t spur on a medium track (80+ ft backstraight) crc black carpet, pit 571/572 compounds. Consistently in the top 3
Reck83 likes this.
Dobbs is offline
Old 09-24-2017, 07:07 AM
  #288
That's perfect, thank you.
Reck83 is offline
Old 09-24-2017, 03:04 PM
  #289
I don't see a thread for the evo, but I am assuming the wing mounts are the same on both vehicles. I had no idea the kit didnt come with a wing. I am wondering what wings fit these cars? The only one i can get in quick are the associated ones. Do they fit?
Thanks,
Washout is offline
Old 09-24-2017, 03:35 PM
  #290
Dobbs's Avatar
Thanks,
Any of the tamiya style wing mounts will fit, i.e. protoform, tamiya, 3racing, montech, zen
Dobbs is offline
Old 09-25-2017, 07:58 AM
  #291
hanulec's Avatar
Trader Rating: 28 (100%+)
(not sure if we need a new thread or not -- please provide opinion on this) i got to run the Rapide F1 Evo this weekend ... and i'm amazed at the changes on the car. the car is light. adding 70g to the car to basically make weight -- which is a great advantage to be able to move weight around.
found an amazing setup with the help of Wayne Gerber and Sam Isaacs this weekend allowing me to set a new track record at 360v2. big thanks to Mike Pags for some magical tire prep that really brought the car to the next level for the main event allowing me to go for 5m w/o a single flip. happy to show any roche drivers this tire prep method at iic -- and to share it publically post iic
chiefj48 likes this.
hanulec is offline
Old 09-26-2017, 06:42 AM
  #292
I just finished building this kit and would love to see your setup if you can post it or PM it! I am new to F1 so this would go a long way for me.
Thanks!
Washout is offline
Old 09-26-2017, 06:59 AM
  #293
chiefj48's Avatar
Please start a new thread n post setup.
mariob62 likes this.
chiefj48 is offline
Old 10-11-2017, 08:27 PM
  #294
gabc's Avatar
Trader Rating: 15 (100%+)
Default Pivot ball bushing, spur gear
Ran the Roche 2016 last night in stock setup on a high grip asphalt track. I'm not sure if i should post this in the Evo thread or here, but i really need some help.
1. Front arms kept hopping like rabbits on steroids during high speed corners with snapping sound of metal rubbing against metal. I believe it's the king pin rubbing against the pivot balls.
(All pivot balls are free with no binding. 7k shock oil on the king pin shaft.)
2. I used pliers to pinch the front arms pivot ball bushing to remove the binding. I think i overdid it. Now the pivot balls pop out very easily. Is there a better solution? I've read in the Roche 2016 thread that Xray bushings will fit. Is this a good solution?
3. Stripped the spur. Noticed it's not perfectly centered. Is there a better alternative?
Thanks very much in advance!
Gab
gabc is offline
Old 10-11-2017, 08:47 PM
  #295
Howler's Avatar
Thanks,
You can mount the Associated wing on the 2016. However I recommend that you shim it, otherwise, you'll be dragging it in the corners. Also, the Evo front body mount post is now available, and will fit into the Associated wing, just like their new F1. Basically a knock off.
Howler is offline
Old 10-16-2017, 08:58 AM
  #296
j.d.roost's Avatar
Trader Rating: 32 (100%+)
http://www.rctech.net/forum/r-c-item...-5-spares.html
Have a really nice 16 for sale
j.d.roost is online now
Old 10-17-2017, 11:07 AM
  #297
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
sg1 is offline
Old 10-17-2017, 12:55 PM
  #298
Trader Rating: 10 (92%+)
Originally Posted by sg1
Need more o rings on top shock mount..
Johnny Carey is offline
Old 10-18-2017, 04:55 AM
  #299
sg1
sg1's Avatar
I could fit 1 more
sg1 is offline
Old 10-25-2017, 05:18 AM
  #300
gabc's Avatar
Default Rear ride height
I want 5mm rear ride height but the highest i can get is 4.5mm. I even fitted new Ride XR tires. Is there any way i can increase the ride height?
I really don't want to file down the motor rack!
Gab
gabc is offline
