Spektrum s6070 not getting full throw
Compared to my team associated ds servos, this spektrum shorty doesn't seem to have as much throw. Both are rated to 60 degrees.
In my 22t, I usually set the travel to 150% with the spektrum. With the ds1015 I have to turn it down to 100% to get the same amount of steering.
With the s6070, it can turn all the way right, but not left. And I cant seem to adjust the linkages to get it right. I have even tried sub trim along with trim and that doesnt help.
Anyone know whats up?
Trader Rating: 53 (100%+)
If you've done the obvious when you installed the servo: center the servo with steering endpoints set at 100 and trim zeroed out before installing the servo horn, and made sure that your turnbuckles are equal length right and left, if possible lengthen the drag link and see if that helps. Always use subtrim to get the servo as close to center as possible before using regular steering trim.
