Like Tree4Likes
Bore = Stroke?
Old 07-05-2017, 01:19 PM
Adamska27's Avatar
Default Bore = Stroke?
So, the new novarossi engine looks sweet.
Um, so why do I care if the bore = stroke? Volumetric efficency of sorts??
Someone make me less dumb please
Adamska27 is offline
Old 07-05-2017, 02:33 PM
8T
8T's Avatar
Long stroke motors are a bit more temperamental about a tuning window. Square stroke motors tend to have a larger tuning window, and are less finicky. There are other reasons, long stroke = more torque, but tuning is what im more concerned with.
8T is offline
Old 07-06-2017, 12:28 AM
There is no way to tell the behavour of an engine. All engines you can compare are all different timed, have different needles in the carb and could have different materials.
On the track all differennt strokes can perform the same.
slashracer111 likes this.
Roelof is offline
Old 07-09-2017, 12:57 PM
slashracer111's Avatar
Trader Rating: 25 (100%+)
+1.
The best way you can learn the specific in and outs about an engine is to buy one. Even two of the same engines broken in by the same person have the possiblity of being very different on the track.
slashracer111 is offline
Old 07-10-2017, 09:09 AM
Adamska27's Avatar
So I do understand that you don't really know until you try.....
And yes, different carbs do different stuff.....
But why is bore = stroke a desirable thing that I might want????
Old 07-10-2017, 09:23 AM
JatoTheRipper's Avatar
Trader Rating: 11 (100%+)
Originally Posted by 8T
Llong stroke = more torque
That's a myth.
Every engine configuration has pros and cons. Novarossi is telling you a square motor is desirable because that's what their marketing wants you to believe.
JatoTheRipper is offline
Old 07-10-2017, 12:15 PM
A change because they have to make changes.... Otherwise we "stupid" consumers will not buy new motors.
Beside that, within Novarossi there are more brands (internal and external) and the different dimensions are splitted to keep the aftersales also with that brand.
Roelof is offline
Old 07-10-2017, 01:18 PM
kgombe's Avatar
Trader Rating: 13 (100%+)
the only possible advantage i can see is the break period will be relatively shorter
kgombe is online now
Old 07-10-2017, 01:19 PM
What makes you say that?
Old 07-10-2017, 01:24 PM
kgombe's Avatar
Shorter stroke = less travel through the mechanical pinch.
Old 07-10-2017, 02:30 PM
timjs's Avatar
So what? It's still an engine revolution.
Anywho,
the square thing is just marketing wank, as stated. There's nothing novel here, these manufacturers just make some little changes here and there and make it out to be a big deal. Which they have to, to make sales.
These engines have like three moving parts...they are so simple there's no magic benefit to a 1:1 bore/stroke. It's just another little specification they can change to make this engine different then another.
No one is going to be changing the game until someone figures out a realistic EFI to do away with the carbs.
timjs is offline
Old 07-10-2017, 02:39 PM
kgombe's Avatar
Are you one of those guys that has to quote someone to flex you keyboard skills...
Anywho I based my comment on engines I've ran from the past and present, the VZB was easier to break in than the XZB the only mechanical difference was the bore stroke.
The Ws7 from rb was easier to break in than it's life g stroke variance the C6... i never onc said performance of some sort would be better or worst...
It is marketing, of course.
Old 07-10-2017, 02:46 PM
timjs's Avatar
I wasnt attacking you, man. My mistake if it came off that way. The majority of my post was just my opinion on the square bit.
As for breakin, I believe "ease" of break-in relies more on the actual amount of interferance present at the beginning. The tolerances of manufacturing can vary a lot. One engine could be fairly loose, another identical engine might need to be preheated to even be able to make it through the pinch.
If tolerances were not a problem, there would be no break-in at all because the engines would be manufactured to exactly the correct clearances from the factory.
Again no attack, just conversing.
kgombe and stanleyw808 like this.
timjs is offline
Old 07-10-2017, 02:51 PM
kgombe's Avatar
This is why I compared engines of same brand or manufacturer and also personal experience, I would think that the tolerance and materials used to be the same..
Just an opinion made on experience..
Old 07-10-2017, 02:53 PM
Engine knowledge all the way!!!! NOT!
Due tolerances the pinch of a normal Novarossi can start at 5 up to 7mm from the upper edge. With a square stroke it is nothing different.... A square stroke is just 0.4mm shorter than the normal long stroke, over the pinch zone in your thoughts it will only differ 0.2 mm or less.
And square stroke new? 15 years ago the square stroke RB WS7 was a winner. Even the WS7-II was a winner between all longer stroke models.
Roelof is offline
