BMI 1/12 conversion/car
#1561
Hi Everyone,
I just wanted to let everyone know that I will no longer be involved with the BMI 1/12 conversion. After the champs I decided to "take a break" If you have any set up questions I'm more then willing to help, send them to me via PM. If you you're looking to order parts or a conversion please contact Jason directly threw his website. Look for Jason to have more cool 1/12 items and the possibility of a complete car Thanks for all the support you guys gave, and good luck racing!!
Wayne
Wayne
#1562
Sorry to hear that Wayne. I understand about needing to "take a break" though. I'm getting close.
Take it easy,
Tim
Take it easy,
Tim
#1563
Set-up
I'm looking for a good set-up for high bite ozite.
Are there any quirks to note with this chassis?
I just got it today.
#1564
Which chassis?
How do I tell the indoor chassis from the ashphalt version?
#1565
search this thread. sg1 posted a good starting setup for carpet. i will find and post link.
don't run the batts full back.
the A chassis has several cut outs. where the Carpet chassis does not. also the carpet is 2.5mm and i think the A is 2.0
#1567
It is a little different from what we talked about today, but it worked very well on high bite carpet. The car needed to be changed a little for CEFX.
I'm gonna be at CEFX tomorrow after work if you want to stop by. We'll go over things if you want.
Talk to ya later,
Tim
#1568
Just want to wish Tim Stamper a HAPPY BIRTHDAY!!
#1570
The carpet car is great. The only quirk is that you must shorten the ball cups on the rear shock as short at you can to reduce pod droop. The over all center shock length on the BMI-12's is a lot shorter than on a 12L4.
Jason tested battery positions last weekend. I always run my batts as far back as they can go. He ended up being fastest with the batts all the way back.
One of the best 1/12th racers on earth told me once that battery adjustment on 1/12th cars is there just for looks and to make bench racers happy. He said always run the battery as far back as you can get it on the chassis.
#1571
Yup, if the munchkin would have waited 2 1/2 hours later, it would have been a great birthday gift. He is wonderful anyways.
Tim
#1572
#1573
sorry, not running the batteries full rear was something that wayne had told me when the bmi12l4 first was released. And I have not tried this since then.
#1575
Adrian,
Battery position is usually dictated by the motor. A mod. motor usually needs the batteries further back then a stock motor. The further back the batteries are with a stock motor the more rear bite and less responsive the stearing. I would run the car almost full throttle on any layout I ran on with a stock motor with the batteries very close to all the way forward. Maybe if you are on and off the throttle in stock it may be easier to drive with the batteries back some. In mod. I had to run the batteries back further to gain initial take off traction, then get the "pendelum" affect as the car went threw the turns to gain stearing. I would also have to run a thinner t-bar in mod. which does the same thing. The mod. motor carries so much more entry speed that the thinner t-bar let the weight transfer quicker and get you threw the turn faster.
Wayne
Wayne
