Old 12-31-2005, 07:38 AM   #1561
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hi Everyone,
I just wanted to let everyone know that I will no longer be involved with the BMI 1/12 conversion. After the champs I decided to "take a break" If you have any set up questions I'm more then willing to help, send them to me via PM. If you you're looking to order parts or a conversion please contact Jason directly threw his website. Look for Jason to have more cool 1/12 items and the possibility of a complete car Thanks for all the support you guys gave, and good luck racing!!
Wayne
sg1 is online now   Reply With Quote
Old 01-02-2006, 08:39 PM   #1562
Tim Stamper's Avatar
Sorry to hear that Wayne. I understand about needing to "take a break" though. I'm getting close.
Take it easy,
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 01-11-2006, 04:49 PM   #1563
Default Set-up
I'm looking for a good set-up for high bite ozite.
Are there any quirks to note with this chassis?
I just got it today.
r1sportbike is offline   Reply With Quote
Old 01-11-2006, 04:52 PM   #1564
Default Which chassis?
How do I tell the indoor chassis from the ashphalt version?
Old 01-11-2006, 05:11 PM   #1565
theisgroup's Avatar
search this thread. sg1 posted a good starting setup for carpet. i will find and post link.
don't run the batts full back.
the A chassis has several cut outs. where the Carpet chassis does not. also the carpet is 2.5mm and i think the A is 2.0
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-11-2006, 06:43 PM   #1566
protc3's Avatar
the asphalt version is 2mm and has alot of pockets in it.the battery slots also go through the chassis.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-11-2006, 08:40 PM   #1567
My Vegas setup is on page 50 if you wanna look at it Kevin.
It is a little different from what we talked about today, but it worked very well on high bite carpet. The car needed to be changed a little for CEFX.
I'm gonna be at CEFX tomorrow after work if you want to stop by. We'll go over things if you want.
Talk to ya later,
Tim
This space for rent
Old 01-11-2006, 09:07 PM   #1568
lmunno's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to lmunno
Just want to wish Tim Stamper a HAPPY BIRTHDAY!!
lmunno is offline   Reply With Quote
Old 01-12-2006, 02:50 AM   #1569
Trader Rating: 14 (100%+)
Hi,
And Congrats go out to Tim S. as he is a new Uncle too!!!!!!!! (and only 2 1/2 before his birhday)
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 01-12-2006, 09:48 AM   #1570
AdrianM's Avatar
The carpet car is great. The only quirk is that you must shorten the ball cups on the rear shock as short at you can to reduce pod droop. The over all center shock length on the BMI-12's is a lot shorter than on a 12L4.
Jason tested battery positions last weekend. I always run my batts as far back as they can go. He ended up being fastest with the batts all the way back.
One of the best 1/12th racers on earth told me once that battery adjustment on 1/12th cars is there just for looks and to make bench racers happy. He said always run the battery as far back as you can get it on the chassis.
Adrian Martinez
Old 01-12-2006, 11:25 AM   #1571
Thanks!
Yup, if the munchkin would have waited 2 1/2 hours later, it would have been a great birthday gift. He is wonderful anyways.
Tim
This space for rent
Old 01-12-2006, 01:16 PM   #1572
James35's Avatar
I would agree with that statement. I personally have never had trouble with front steering traction. I can easily get more steering traction at will. It seems I could always use more rear traction, and having the batteries far back increases rear traction.
James35 is offline   Reply With Quote
Old 01-12-2006, 01:21 PM   #1573
theisgroup's Avatar
sorry, not running the batteries full rear was something that wayne had told me when the bmi12l4 first was released. And I have not tried this since then.
yang lai
Old 01-12-2006, 01:44 PM   #1574
AdrianM's Avatar
Wayne is "The Man" but I don't necessarily agree with that part of his setup. I think he could be even faster if he moved the batts back and looked for the feel he got from moving the batts forward elsewhere in the car.
Adrian Martinez
Old 01-12-2006, 09:10 PM   #1575
sg1
sg1's Avatar
Adrian,
Battery position is usually dictated by the motor. A mod. motor usually needs the batteries further back then a stock motor. The further back the batteries are with a stock motor the more rear bite and less responsive the stearing. I would run the car almost full throttle on any layout I ran on with a stock motor with the batteries very close to all the way forward. Maybe if you are on and off the throttle in stock it may be easier to drive with the batteries back some. In mod. I had to run the batteries back further to gain initial take off traction, then get the "pendelum" affect as the car went threw the turns to gain stearing. I would also have to run a thinner t-bar in mod. which does the same thing. The mod. motor carries so much more entry speed that the thinner t-bar let the weight transfer quicker and get you threw the turn faster.
Wayne
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
