New Losi 350 destroyed by shattered crank bearing >
Old 06-08-2016, 04:29 AM
  #16
Originally Posted by Micah78
Thankfully your engine was just a Losi 350 lol! I had the same thing happen to a Clockwork modified Nova .28. My switch on my reciever pack went bad and off went my RC8T across my yard. It hit a boulder and flipped upside down. Then it wailed like a banshee till I grabbed it and stopped it with my shoe on the flywheel. It also gave me a "rug burn" from the ballooning tires getting my leg. I was still in my break in period and never got to see what my $450+ engine could do. The high RPM spun a crank bearing and sucked it through the engine. My piston looked like yours!
Wow, that's scary. My condolences! I have a spring installed that hopefully pulls the carb close should I ever end up in a power-loss situation. The spring is not strong enough to pull overcome the servo when the engine is stopped but I hope that with a running engine, the vibrations help to close the carb. Luckily never had to find out.
I've installed a Nova R21 that I had around.
FabianT5 is offline
Old 06-08-2016, 07:11 PM
  #17
I had a throttle return spring and overlooked using it. It's probably the first time I ran a nitro without one. It's on my current engine though! I also don't use a switch for my reciever batt anymore. I just plug and unplug my battery now.
Micah78 is offline
Old 06-09-2016, 10:01 AM
  #18
Even if it slows the car a little bit by closing the carb., it would be enough to catch the car and stop it. I'm driving on a beach so it is too risky not to use spring or else it might end up in salty water.
PlanB is offline
Old 08-13-2016, 10:36 AM
  #19
Update: Kudos to the Horizon Hobby Service Center. I sent this engine to Horizon Hobby and without any complications, they notified me that they are going to replace the entire engine for free!! That's awesome.
FabianT5 is offline
Old 08-13-2016, 08:29 PM
  #20
i ruined a like TT 21 a few years ago by not knowing how to tune it. the piston turned black and would not turn over. I replaced it with an OS vg21 and that was a damn good engine.
stoney452 is offline
