KE21R CARBEURATOR
Does somebody know if the carbeurator on a KE21R engine can be exchanged to other brand? and if so, what brand would fit, and what size? (couldnt find specs)....
This stock carbeurator it had in place, had plastic inlet valve and when i tried to move inlet valve a little to the side in order to fit in a longer fuel line to carbeurator , the gasket wich is small round flat donut, came off torn and cannot find a replacement carbeurator rebuild kit for this cheap carb.
I would rather buy a different carbeurator but not the whole engine since it has been only ran about 15 times for 10 mins. Hence the original carb is only $ 17 at ebay ( new ). What would fit it ? talking about a TKI3 RTR kit.
Picco carbs have a shaft of 14mm, novarossi has 15mm
and what does the size mean if one is 14 and other is 15...??, do they fit it ?
That is the shaft that goes into the engine. Meassure that one up of your carb and you will know.
I believe LM based engines like XRD, Sirio and Orion have also a 15mm shaft.
