BMI Racing Discussions
#6406
Originally posted by jag88
Jason, How long after the new Xray is out until you come up with a chassis replacement. I have your chassis for the current Xray and it's very good.
Thanks.
Thanks.
#6408
Originally posted by protc3
as soon as i get my hands on a new FK05 it will be in the engineering phase
cant wait..
#6410
will the TC4 BMI chassis have holes drilled to allow the duct and fan kit to be installed? i may be interested in a chasis kit when its released if it does have the right holes for the duct etc
#6411
Hi to Jason and all you BMI drivers! Well I tried the settings last night u guys suggested for my tc3 bmi and mate what a difference , I've now managed to get the car to about half a second of the pace of my tub tc3 but its only getting quicker. the only problem is still a little loss of rear traction, the car seems to get mid corner and start to drift around, which can see some impresive fishtails, but I like it to be glued. The steering is heaps better took kickup out 4* blocks,1* camber layed socks in 1 hole rear tower on frt,outer hole on lower arms. on rear 2*kickup,3*toe, in 1 hole on tower,outer hole on arms,1.5*camber, blue springs frt & silver rear tried frt swaybar to gain rear traction but seemed to slide more,added a half turn droop on rear and seemed to get better. Was running 6 droop frt and 4 on rear before change and sorex 28 med b inserts. Any other tips. heaps of thanks so far for the info I love this car.
#6412
And ran a oneway!
#6413
i would lengthen the rear camber link and also set the wheelbase to short position.this will put more weight over the rear tires and give a little more traction.i would try about 1/2 degree camber in the front with the 4 degree caster.leave the rear at 1.5 and try that out.let me know how it goes.
#6415
Originally posted by Jon Kerr
Jason, did you get the PM I sent you a couple days ago?
#6416
i just bought the new tc4 upper chassis brace i cant wait to recvie it my friend drives for them and i makes a good bit of difference on the car and the siffness too
thanks alot portc3
later
thanks alot portc3
later
#6418
Sorry wrong thread! Doh!
#6419
when is the tc4 chassis going to be relased?
and what is the price going to be ?
thanks
thanks
