1/8 Offroad Buggy
#301
try ebay. theres one for $115
heres my setup:
stock aluminum clutch and springs
TOP P5
0S2050 in line pipe with waller for the 063
heres my setup:
TOP P5
#303
heres my setup:
TOP P5
heres my setup:
TOP P5
i also wanted to let you i tried your 5/10/2 combo - it felt pretty good, but i think i drove it better 7/10/2. thanks for the suggestion, it's always good to try different things and see if it suits you or not.
#304
...cool.
...I used a small amount of JB weld around the valve...just enough to reinforce it.
I am running 5/10/2 right now with 35f/30r stock shocks 7mm shock limiters front and back. And it handles great.
#307
Hey tambok can you compare the 2050 to an 063? how does it compare powerband wise, does it still have that nice kick down low? i've considered buying one because the RB polished pipes dent up very easily, even though I like how they perform i'm tired of them denting, so thinking of trying the OS.
#309
0S2050 is like the 086 pipe....but in my case I had to add the waller adapter to give me more torque at my track.....aside from that, top end is awesome......
#310
Steering Servos
Going back to steering servos again:
I have to say that I have had nothing but good experiences with Hitec servos on my nitro models. I've seen more dead Futabas/KO servos than I have Hitec. I've only ever heard rumours regarding Hitec servos and in the most part, these are completely unfounded in my experience.
I've used old 615's, 625's, 645's and had no problems with them on either throttle or steering for years! Mucho cheapness!
More recently, I've used Hitec digital 5925's for steering on my MBX4 RR and they are very quick AND have over 9kg of torque @ 6v, again, with no problems whatsoever. I have also used the Hitec digital 5945's, exactly the same as the 5925 but geared for more torque/less speed - 13kg of torque (!!) and still a fast servo, an excellent choice for either 1/8th buggies or MTs. Cost? 40 percent less than some of the main rivals!! Nuff said.
I reckon the biggest problems these servos are likely to encounter is the 'brand name' perceptions that racers seem to adopt so readily.
#311
im glad you've had good experiences with hitec servos
but alot of people havent
im 1 of them
i bought 6 hitec 5925s for 3 cars i had within 1 year 4 failed and within 2 years 7 total times a hitec servo has died on me
now i have to admit they have warrantied these servos every time ive sent them in (thank-you hitec i do appreciate this)
but the fact is from what ive seen with my own stuff hitec has a higher than average failure rate
im 1 of them
#312
Re: Steering Servos
#313
i, third that notion. it's good you had no problems. howver, i haven't been as fortunate. on a positive note, hitec did replace my damaged servos. i'm pretty much stuck on airtronics. they've been reliable, and local to me if i break 'em. besides, (as i've mentioned before on another thread) bobby tom @ airtronics is a cool man and a wealth of knowledge - kick ass customer service.
on a totally different note, tambok gt - big ups and kudos for suggesting the os 2050... and the jb weld. the jb weld was simple to mix and cured w/o any problems. i ran the pipe yesterday (setup the same from prior), and you're right. it felt like an 063 @ the bottom (maybe even too torquee) w/ the waller, and had still had a grip @ the top. i'd been running my p-5 w/ the 086 and waller. with the os, the top is the same if not more, and the bottom was kick ass!
#314
im 1 of them
im 1 of them
I've had problems with the potentiometers they use in their Tx's, but nothing else.
#315
I don't really care for anymore topend, but I really like the kick down low with the 063 - is the 2050 with waller at least very close to that? sorry, im hearing different answers lol
about servos - guys, i guess it doesnt matter - just use what you like (and have had good experience with) and stick with it. Seems like everyones had problems with every brand (okay, ive heard about hitec more than others) but yeah if we were to go by that there'd be nothing to pick.
I've personally run futaba all my life and never had a problem, so i'll stick with it. If it's the same for you and hitec, horatio, why the hell not
