Team Losi JRXS
Old 10-24-2005, 01:08 AM
  #8521
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Originally Posted by JRX-S Bill
Hope this shows well...
Any idea on where to drill the hole for the camber link attachment??? everything else looks straight forward, just not sure where to drill???
DirtyDog3375 is offline
Old 10-24-2005, 04:03 AM
  #8522
geeunit1014's Avatar
Trader Rating: 14 (100%+)
drew85 ygpm
geeunit1014 is offline
Old 10-24-2005, 09:17 AM
  #8523
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Gil Jr. should get credit for alot of things, not only the camber link mods, ! haha
It's like when the TC3 first came out and none of the team A/E guys could get a handle on it and were doing poorly. Cliff Lett came out and got them up to speed in only a couple races.
Gil Jr. has the same effect for the TeamLosi crew, i've seen it time and time again, it's no fluke.
Cliff and Jr are like the R/C professors and there are alot of others, like Hodge, Wenger, etc who are in the class, but most of us haven't even been accepted to the school yet and our resume is being revued at best, hahaha.
...Jim
W.E.D.Jim is offline
Old 10-24-2005, 09:54 AM
  #8524
ghoppa's Avatar
Trader Rating: 63 (98%+)
Default message
Scott Welte,
YGPM'ed......
ghoppa is offline
Old 10-24-2005, 12:01 PM
  #8525
TLRacing
Todd Hodge's Avatar
Originally Posted by Yeti35
Ok Bill, you got my interest peaked, what does this mod do and how soon should I start getting some arms and makin my own? I'm going to assume that it makes the front end stiffer.
The camber mod is just giving you a longer front camber link. We feel that it gives the car the same amount of steering but makes the car easier to drive in high bite conditions.
Todd Hodge is offline
  #8526
TLRacing
Todd Hodge's Avatar
...Jim
Thanks for the compliment there!!
Old 10-24-2005, 12:57 PM
  #8527
EricF's Avatar
Anyone have the part number for the turnbuckles available?
Thanks,
E
EricF is offline
Old 10-24-2005, 02:41 PM
  #8528
Todd, already made up my pieces for the front camber link mod, and got it installed on the car. Will find out how it works on Friday's practice day for the Halloween race.
BTW, for anyone who doesn't have any Losi 0 deg castor blocks to cut up, I used some old TC3 stock graphite 0 deg castor blocks. Plenty of those lying around, as they were never used on the car.
As for measurements for where to drill the hole for the turnbuckle, I drilled 10 mm in from the 'back' edge of the cut up arm. Meaning, the edge opposite from where the hole for the shock is molded in. The arm itself is cut off just at the 'edge' of the molded rib where the shock mounts. You want to keep this as thick as possible while still having a flat surface to drill into for the turnbuckle.
The pic shown by JRXS Bill shows alot of dremeling and rounding of the rear edge of the arm. Not sure why, as my Parma 28 mm foam tires easily clear both sides of the arm with no trimming required. Only trimming necessary is to make more clearance for the top of the C block when you compress the suspension.
I could see this mod being more difficult for people running on asphalt, as generally more suspension travel is needed and the C block will tend to hit the cut off piece of A arm on top of the C block. But running foam tires on carpet, you only need 5-6 mm of suspension travel total.
The new A arms are coming out soon, now Losi needs to make some new C blocks to incorporate this new camber link mod, without having to hand make the parts
Stealth_RT is offline
Old 10-24-2005, 03:49 PM
  #8529
POOKYT's Avatar
Originally Posted by EAMotorsports
Oh ok...Well either way it looked a ton better!!
EA
Eric--Ya snoop'n round the JRXS thread now??? LOL!
Brant
POOKYT is offline
Old 10-24-2005, 04:42 PM
  #8530
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
Is that a a arm cut down on the camber link mod? I keep looking at that pic and that is what it seems to be.
wyd is offline
Old 10-24-2005, 05:18 PM
  #8531
Yes, it's a stock lower A arm cut down, and the bottom part of a 0 deg caster block, that's screwed to the top of the caster block you are using on the car. Don't forget to put in another metal bushing in the added piece of caster block when you put the screw down thru it into the steering knuckle!
Old 10-24-2005, 07:06 PM
  #8532
Trader Rating: 16 (100%+)
Exactly.
Still Bill is offline
Old 10-25-2005, 05:28 AM
  #8533
W.E.D.Jim's Avatar
Todd, I was figuring only a few would even understand the post, haha.
Keep up the hard work.....Jim
Old 10-25-2005, 07:03 AM
  #8534
Mike Haynes's Avatar
Todd, Would there be any reason to try these upper mounts in the back also?
Mike Haynes is offline
Old 10-25-2005, 08:52 AM
  #8535
TLRacing
Todd Hodge's Avatar
I don't think so...but you never know :-)
