Ofna Cd-3
#1097
spenzalii
I attach to both ratio tray and chassis. Only servos I have killed in my RC years where S3003 and Hitec. Once I went KO (about 3 months into my R/C) no dead servos since (~4 years now). Digitals on steering, Analog servos on Throttle.
I did some research and found your problem though..
I just have one question, was it another crappy brand servo? hehehe
If it wasn't (a hitec) you might have steering binding or end travel too far?
Originally Posted by spenzalii
Turn on the radio fir a quick check, and I have no throttle servo! My Hitec quit on me at the worst possible moment
I got the car back together, reinstalled the hitec servos (say what you want, but their customer service rules!)
#1098
Giggles on the Hitec thing. Neither of the sevos on the LD3 were Hitec. I blew a Bluebird (cracked case, bent an internal shaft on one of the servo gears) and a Futaba digital (I'll take it apart at some point to see if the same thing happened). Endpoints set so they don't overextend. Then again, trying to nurse a broken car around a track could cause some strain.
#1099
starter box
please help i cant line up my cd3 to my q world s/box
i have tried every posable angle the only way i can see it fit
is to cut/drill an modify and that i dont want to do.. has any one got pics on how there QWORLD BOXES ARE SET UP ??? the no on it is 10243
thanks
thanks
#1100
Is it this one: http://ofna.com/images/st-sb-10243-big.jpg
Because this one will fit with no problem. If it's another one, send a link.
#1101
ahh bugger spenzalii, I thought I had you
#1102
thanks
thanks
#1103
#1104
spenzalliiiii yes thats the one i got
#1105
spenzalii just a few Q: then :P
I wont worry about the bluebird - as forum search kinda said enough the quality...
re: the futaba, not that I own one I believed these where ok, it was not used on the thottle was it? (digitals for steering, analog for throttle)
#1106
Ofna Starter box
I use the small OFNA box for my CD3 Pro car and CD3 RTR cars. It helps setting up the chassis alignment if you have a blank chassis plate available.
The right wheels are close to the starter box just because it has to be offset to align the flywheel to the starter wheel.
I also mounted and angle bracket on each side to ensure chassis alignment.
If I had one mounted on the rear the box would be perfect.
I also clearenced the flywheel access area of the chassis with my dremel tool.
#1107
#1108
Shouldn't be too much of a problem with that box, as it was designed for engines offset to the right. I set the front guide in between the chasis and the lower arms and moved it forward until the starter wheel was under the flywheel. Leave the posts semi-loose so you can adjust thel fore and aft and left and right until you get it just right and the starter wheel doesn't rub the chasis, then tighten the front and rear posts up. I don't think mine sits too far on either side (then again I didn't think to check, either), and I didn't have to grind the chasis at all. It's a trial and error thing, but you should be able to get it with a little time.
ok i will try againe thanks .btw you dont have any pics of your set up do you
#1110
I'll try and take some tonight when I get home.
thanks mate
