Old 08-16-2006, 08:20 AM   #1096
trumpster1's Avatar
My sterring servo is mounted to both the chasis and the radio plate. I have had 0 problems with the steering servo, but I have blown two throttle servos.
Nathan
Spektrum DX3R
Traxxas 2wd Slash
Ex-One Eighth Racers of Toledo member :( no mo money
trumpster1 is offline   Reply With Quote
Old 08-16-2006, 01:53 PM   #1097
spenzalii
I attach to both ratio tray and chassis. Only servos I have killed in my RC years where S3003 and Hitec. Once I went KO (about 3 months into my R/C) no dead servos since (~4 years now). Digitals on steering, Analog servos on Throttle.
I did some research and found your problem though..
Originally Posted by spenzalii
Turn on the radio fir a quick check, and I have no throttle servo! My Hitec quit on me at the worst possible moment
I got the car back together, reinstalled the hitec servos (say what you want, but their customer service rules!)
I just have one question, was it another crappy brand servo? hehehe
If it wasn't (a hitec) you might have steering binding or end travel too far?
au_Nightmare is offline   Reply With Quote
Old 08-17-2006, 10:33 AM   #1098
spenzalii's Avatar
Send a message via AIM to spenzalii
Giggles on the Hitec thing. Neither of the sevos on the LD3 were Hitec. I blew a Bluebird (cracked case, bent an internal shaft on one of the servo gears) and a Futaba digital (I'll take it apart at some point to see if the same thing happened). Endpoints set so they don't overextend. Then again, trying to nurse a broken car around a track could cause some strain.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 08-17-2006, 11:13 AM   #1099
Default starter box
please help i cant line up my cd3 to my q world s/box
i have tried every posable angle the only way i can see it fit
is to cut/drill an modify and that i dont want to do.. has any one got pics on how there QWORLD BOXES ARE SET UP ??? the no on it is 10243
thanks
serpentrush is offline   Reply With Quote
Old 08-17-2006, 12:28 PM   #1100
spenzalii's Avatar
Is it this one: http://ofna.com/images/st-sb-10243-big.jpg
Because this one will fit with no problem. If it's another one, send a link.
Old 08-17-2006, 01:46 PM   #1101
ahh bugger spenzalii, I thought I had you
Old 08-17-2006, 06:18 PM   #1102
Mcfly's Avatar
thanks
hi i have a Q World box and i did drill the screw holes out slightly to fit it,i have been using it with my CD3 Pro for the last year and a half, the only thing is the right rear wheel is very close to the box, heres a pic.
Mcfly is offline   Reply With Quote
Old 08-17-2006, 08:12 PM   #1103
spenzalii's Avatar
I know, nice try. Of course, I run this weekend (last race of the season), so it's just about time for something to go bad. If the engine goes, I have another one. Pipe? Got one of those. Gears, arms, knuckles, shock towers? Affirmative. Servo? I'm dead in the water.
Old 08-17-2006, 09:15 PM   #1104
spenzalliiiii yes thats the one i got
Old 08-17-2006, 09:34 PM   #1105
spenzalii just a few Q: then :P
I wont worry about the bluebird - as forum search kinda said enough the quality...
re: the futaba, not that I own one I believed these where ok, it was not used on the thottle was it? (digitals for steering, analog for throttle)
Old 08-17-2006, 09:39 PM   #1106
CurveTracer's Avatar
Default Ofna Starter box
I use the small OFNA box for my CD3 Pro car and CD3 RTR cars. It helps setting up the chassis alignment if you have a blank chassis plate available.
The right wheels are close to the starter box just because it has to be offset to align the flywheel to the starter wheel.
I also mounted and angle bracket on each side to ensure chassis alignment.
If I had one mounted on the rear the box would be perfect.
I also clearenced the flywheel access area of the chassis with my dremel tool.
CurveTracer is offline   Reply With Quote
Old 08-18-2006, 07:43 AM   #1107
spenzalii's Avatar
Shouldn't be too much of a problem with that box, as it was designed for engines offset to the right. I set the front guide in between the chasis and the lower arms and moved it forward until the starter wheel was under the flywheel. Leave the posts semi-loose so you can adjust thel fore and aft and left and right until you get it just right and the starter wheel doesn't rub the chasis, then tighten the front and rear posts up. I don't think mine sits too far on either side (then again I didn't think to check, either), and I didn't have to grind the chasis at all. It's a trial and error thing, but you should be able to get it with a little time.
Old 08-18-2006, 12:54 PM   #1108
ok i will try againe thanks .btw you dont have any pics of your set up do you
Old 08-18-2006, 02:42 PM   #1109
spenzalii's Avatar
I'll try and take some tonight when I get home.
Old 08-18-2006, 03:15 PM   #1110
thanks mate
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
