BMI's DB12R
#1878
Too bad Snowbird is on opposite surface of Earth (means 20+hrs flight time), otherwise I would love to attend..
#1879
Not a problem buddy. We have what i believe is the best car. Now i just need to get it in the hands of the best drivers so i can prove it.
Alot of the cars out there do well at the big races because of who is wheeling the car. Once we accomplish that, The competition is in deep trouble. I am working on making this happen
#1881
Here is my car. Jason feel free to use it on website..
I know someone probably ask, the bumper is from Kawada which I knife it down a little bit and drill new mount holes, the ESC is GM SX9 with Novak transcap behind.
#1884
Hey guys,
I forgot to tell you,the new front ride height adjusters are in stock and ready for shipment. The rear axle shims will be in stock on tuesday. These are the shims that will eliminate the need for washers on the axle. 1 on each side will bring you right to 172mm. They will be high finish aluminum spacers. It will give you the bling without the agrivating task of setting the track width and centering the axle. Now it will be done without any thinking
#1885
Jason,
Ran the car on Tuesday night after Sunday’s race when I ran the FF’07 DB12R not ready.
This was done after the carpet had aired for 2 days and was the same layout.
Only had two runs using same motor (unskimmed) & tyre type and,
Single lap faster by 1.17s
Average lap down by 1.057s
Unbelievable the way the car corners with speed.
Only place I seemed to struggle was in the switch backs (left/right/left) were the car was to responsive. Maybe addy & or servo KO949. (Usually run a Sanwa 141)
Tried the olive spring to gain a bit more rear end.
Car seemed to be skipping a lot under power on the rear.
Body: Hot Bodies Ferrari (used as I like it and didn’t have a Parma ready)
Tire Compounds: BRM Purple/Grey = f 44mm r52mm
CS High Grip Tyre Additive : Full front & Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 10* Block
Caster: Middle
Camber: set to run foams square
Ride Height: 3.5mm
Toe: zero
Front Track: no shims on axles
Front Spring: .020”
Front Preload/Droop: No Preload/very little
King Pin Damping: none (don’t like to do it)
Servo Mounting: Angled
Shock Length/Pod Droop: 2.6” (66mm)/.060 (1.5mm)
Shock Angle: Med IRS ball stud on AE Ant-Shock mount
Shock Spring: AE gold / AE Olive
Shock Oil: 35wt
Side Damper Oil: 100wt shock oil (no heavier oils)
Flex Plates: .070”
Flex plate preload screws: Not installed
Rear Body Mounts: To the rear
Rear Track: 172mm
Track Layout
Caster: Middle
Ride Height: 3.5mm
Toe: zero
Front Spring: .020”
Shock Oil: 35wt
Flex Plates: .070”
Rear Track: 172mm
Track Layout
ran the following today on same track layout today and best lap of 14.73s with the setup edited in blue below,
Tire Compounds: GRP Magenta F&R = f 44mm r50mm
CS High Grip Tyre Additive : 3/4 front & Full Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 5* Block
Caster: Middle
Ride Height: 3.5mm
Toe: zero
Front Spring: .020”
Shock Spring: AE Blue
Shock Oil: 35wt
Side Damper Oil: Medium Corally Damper Syrup
Flex Plates: .066” thin
Rear Track: 172mm
Motor: 19t BRM XXX brush +&- 42.8mmpr same as last time but not shown
#1887
#1889
I was running 19t brushed so well please with lap time v the brushless motors
#1890
Anyone have pics of this car with a lipo in it?
Is there even a lipo that fits?
Lipos are legal at bolth my tracks, so im going all lipo FINIALLY
