Like Tree2Likes
Xray T4 '13
Old 02-16-2013, 11:39 PM
  #2776
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Originally Posted by elee32
how much fluid are you putting in the diff? I thought I had a leaky diff when I built my first few, only eyeballing the amount of fluid I put in. Once I put the empty diff on a scale and added the fluid by weight like the directions suggest haven't had a leak since. Leads me to believe it was more of an overflow problem than a leaking problem.
Hope that helps!!
I was concerned about this too but I was even more careful on the 2nd rebuild. I put in a bit less than what the manual recommended, but pretty much by the 2nd qualifier, I noticed the rear end of my car was getting all oily.
Anyways, going to try another rebuild. Leaving the large O-ring out though. Hopefully 3rd times a charm.
Dan is offline
Old 02-17-2013, 11:33 AM
  #2777
Originally Posted by Adam B
The o-ring has been found to be not needed. You should be ok with just the paper gasket.
+1
eded1 is offline
Old 02-17-2013, 04:08 PM
  #2778
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
i ca the o-ring and never replaced them,changed diff oil numerous times in 4 diffs still using same o-ring
Warren Weaver is offline
Old 02-17-2013, 04:14 PM
  #2779
Skiddins's Avatar
T4 running 13.5 boosted
Tried a resonable setup but it seemed to be a bit too 'stuck' through corners, almost like i had drag brake on.
Decided to try 1 hole rear uprights (as advised by several team drivers) which made it a pig to hold on to during the race.
You can see my car squirming and sliding through corners.
Back to 2 hole methinks;
+ YouTube Video
Skiddins is offline
Old 02-17-2013, 04:53 PM
  #2780
CristianTabush's Avatar
Trader Rating: 13 (100%+)
Skiddins, how much rear toe are you using?
My experience with the T4 is at our local asphalt track, however, the track is extremely high bite when they spray it with VHT. One night, they were experimenting with more track additive after the races. Before the extra additive I was running 11.3 and 11.2 second laps, post the additive the lap times became 11.7's and 11.8's. As I had just gotten my car I had pretty much 0 option parts to find the speed. Luckily, the car has been very responsive to geometry changes.
The first thing I did was remove rear toe. I went from having 1.0mm shims in between the rear suspension blocks and the bulkhead to 0.5mm shims. The car got better. Next, I reduced Droop by turning each screw about 1/8 of a turn clockwise. I also shortened the wheelbase by 1mm in the rear. Alll the adjustments made the car less stuck and lap times started dropping. Next I went to the second hole from the outside on the front shock tower to increase mid corner rotation and lastly I lowered the inside camber links to only 1mm underneath all 4. I am also running the shortest links all around. After all the changes were made, I was able to get my lap times down to 11.0.
While I know the surfaces are different, the feeling of a car being too stuck is the same from my experience on both carpet and asphalt- all the adjustments I used, should work on both surfaces to "free up the car" and get more corner speed.
I have followed the thread for a while and noticed some people have said that the car lacks corner speed in certain circumstances, however with my limited time with the car, my favorite thing about it has been the corner speed and acceleration characteristics. What would be interesting to find out is what adjustments people have been trying on their cars to get them to reduce traction in high grip conditions.
CristianTabush is offline
Old 02-17-2013, 05:15 PM
  #2781
Trader Rating: 23 (100%+)
A few days ago I changed to EA's Snowbirds setup, dropped a tenth or two off my average. Freed the car up a little without being squirrely, it's really worth a try IMO.
pcar951 is offline
Old 02-17-2013, 06:52 PM
  #2782
erchn's Avatar
Any idea where the 2.4 springs on EAs setup came from?
erchn is offline
Old 02-17-2013, 07:01 PM
  #2783
Team EAM
Trader Rating: 79 (100%+)
Try the 2.5's instead. The 2.4's were preproduction ones that they never made into production. They made the soft progressives instead.
EA
EAMotorsports is offline
Old 02-17-2013, 07:17 PM
  #2784
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Anyone care to measure the center to center of the holes on the chassis for the battery holders? Want to see if the new adjustable ones will work on the TC6.1..
Shhh. don't tell the team.. lol.
Logi Maker is offline
Old 02-17-2013, 07:21 PM
  #2785
erchn's Avatar
EA
Ok, bummer, thanks. Maybe reflex will have some options in that range.
erchn is offline
Old 02-17-2013, 07:50 PM
  #2786
Riketsu's Avatar
Trader Rating: 34 (100%+)
I believe I have seen CSO in that range. No idea how they compare to Xray (2.5 vs 2.5, etc)
Riketsu is offline
Old 02-17-2013, 07:59 PM
  #2787
hotrod1933's Avatar
Default re asphalt
just got a second t4 running with a different motor combo. 21.5 blinky.
complete kit asphalt setup at the moment.
med grip painted asphalt no compounds or spray
car is as quick as first (also kit setup) but has a low speed on power loose and a high speed sweeper push. everything i read these need the opposite to correct. swapped to a mazda from ltcr and push was worse.
hotrod1933 is offline
Old 02-17-2013, 08:07 PM
  #2788
erchn's Avatar
Two cars, same setup, different results?
Maybe check your weight distribution. Might be too heavy in rear. Also kinda sounds like a tweak, lefty loosey righty tighty.
erchn is offline
Old 02-17-2013, 08:33 PM
  #2789
hotrod1933's Avatar
one is brand new the other just got a new bottom deck so should not be tweaked but will check. slightly different electronics but only the esc and both very close to same weight. both cars are a bit loose but no 2 is worse and has the more push. diff oils are different just remembered no 1 is 1200 and no 2 800. will even try same tire set on each car tomorrow not different sets.
will go over both cars tonight might be a slight difference in droop or something.
Old 02-17-2013, 10:28 PM
  #2790
Sorry, I should have mentioned I used 2.5s in the rear. Couldn't find the 2.4s anywhere, now we know why. Thanks Eric!
pcar951 is offline
