battery taping teqnique
what is the proper method for taping batteries in
i allways have trouble
thanks for help
thanks for help
Always, leave no slack in the tape. If you can move your pack around, pull the tape loose and re-tighten. There are three things that will lead to broken tape; non-rounded edges on the chassis that the tape passes over, and loose tape. The other is an impossibly heavy collision, which will usually do more damage to a chassis than just launching a battery pack. By taking the slack completely out of the tape, the battery pack cannot gain momentum to break the tape, and the tape will spread the load of the impact across the whole width of the tape, not just a single edge, which will start a tear in the tape.
I always use Speed Merchant's black strapping tape (smr5024). Not only is it strong, I love the fact that it's black.
http://nexusracing.net/product_info....12167fbc7e845f
http://www.speedtechrc.com/store/ebp...nid=327&id=835
Thats the stuff i use for my 007, i lay out a long piece at the start of the night. I over lap the peice, after the first run i add a second strip accross the top of the pack the main strip stays on the chassis for the night i just re-use or add new strip acrross the top between runs, for the main. Cells never move
No technique really, just make sure that the tape under the car is flat, and that the tape on top of the cells is secure.
Only the piece of tape that goes from the chassis slot, to the top of the end cell/s, is doing any work, the rest is just decoration. There is no need to cross the tape on top of the cells (as the pack is solid by virtue of the battery bars) or even under the car (as long as the tape has enough purchase on the chassis) because it is not doing any work to keep the cells in in these areas.
It is easy and convenient to use one piece of tape going all around the cells, as it ensures that nothing comes unstuck from the end cell/s and teh chassis. To avoid tweak in the car, make sure that you don't pull the tape too tight as it comes from the chassis to the end cell/s. Otherwise, keep it gently taut, and neat. HTH
I like to make a loop at each end of the pack. This loop only goes around the slot, not under the chassis. Join the loops with a top piece of tape with some tension and the battery is secure. Leave the loops on for weeks at a time while only using a short piece each time the battery is removed.
Oh yeah....the TAPE itself MATTERS............don't buy the fancy colored one just because it match your colored bulkhead or alum parts, get the GOOD ONE that sticks.
I have the black one from Nexxus Racing...last FOREVER...and when your batteries getting warm while running it, it sticks even better....I use 1 round of tape for multiple practice, 3 qualifier and the main....but sometime I will change to another one after then 2nd qualifier.....just a piece of mine of preventing the tape get loose.
can you use electrical tape or will that hurt the battery?
thanks for the replys
i just use fiberglass tape from the local hardware store
T2 007 sedan and Corally SP12X pancar
That stuff doesn't work quite as good. It will wear through that stuff on asphalt. Go with the other stuff recommended above, its better; trust me, been there done that.
ok
il order a roll of that stuff
thanks for the input
PS u talking about the cars or the tape?
Couple reason why the tape broke (cutted...)
(1)...carbon fiber chassis not sanded smoothly...make sure sand the battery tape slot round and smooth.
(2)....bad tape, ie, the NON-RC use fiber tape...even the 3-Com one....
Forget about electric tape...when it get warm (your batteries will get hot while running)...those tape tend to get soft. It won't break...but it will get loose. And when your tape got loose...expect to see your 6 cells flying out at the next corner....
