Old 10-08-2007, 11:21 PM   #1
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
Default battery taping teqnique
what is the proper method for taping batteries in
i allways have trouble
thanks for help
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 10-09-2007, 07:24 AM   #2
rcarmchl's Avatar
Trader Rating: 15 (100%+)
what kind of trouble are you having?
rcarmchl is offline   Reply With Quote
Old 10-09-2007, 07:59 AM   #3
timmay70's Avatar
thanks for help
For 12th scale or sedan? The same principals apply to both. I cut the tape so that it will overlap across the top fully. Slide the tape between the link with enough tape sticking out the top to go across the whole top of the assembled pack. Slide the other end of the tape between the link and chassis, and pull tight. At this point, I usually will push the tape back so that the tweak plate will hold the ends of the tape out of the way. Install the battery pack. Pushing the pack down into the chassis nice and tight, pull one side of the tape over the top of the pack, keeping the tape as tight as you can without bending the chassis, then repeat for the other side.
Always, leave no slack in the tape. If you can move your pack around, pull the tape loose and re-tighten. There are three things that will lead to broken tape; non-rounded edges on the chassis that the tape passes over, and loose tape. The other is an impossibly heavy collision, which will usually do more damage to a chassis than just launching a battery pack. By taking the slack completely out of the tape, the battery pack cannot gain momentum to break the tape, and the tape will spread the load of the impact across the whole width of the tape, not just a single edge, which will start a tear in the tape.
I always use Speed Merchant's black strapping tape (smr5024). Not only is it strong, I love the fact that it's black.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-09-2007, 08:02 AM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
thanks for help
Not sure if there is a special technique. It really comes down to the tape you are using. The better the tape the better it will hold. I use this tape...
http://nexusracing.net/product_info....12167fbc7e845f
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-09-2007, 09:00 AM   #5
Joel Lagace's Avatar
http://www.speedtechrc.com/store/ebp...nid=327&id=835
Thats the stuff i use for my 007, i lay out a long piece at the start of the night. I over lap the peice, after the first run i add a second strip accross the top of the pack the main strip stays on the chassis for the night i just re-use or add new strip acrross the top between runs, for the main. Cells never move
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-09-2007, 10:15 AM   #6
No technique really, just make sure that the tape under the car is flat, and that the tape on top of the cells is secure.
Only the piece of tape that goes from the chassis slot, to the top of the end cell/s, is doing any work, the rest is just decoration. There is no need to cross the tape on top of the cells (as the pack is solid by virtue of the battery bars) or even under the car (as long as the tape has enough purchase on the chassis) because it is not doing any work to keep the cells in in these areas.
It is easy and convenient to use one piece of tape going all around the cells, as it ensures that nothing comes unstuck from the end cell/s and teh chassis. To avoid tweak in the car, make sure that you don't pull the tape too tight as it comes from the chassis to the end cell/s. Otherwise, keep it gently taut, and neat. HTH
SlowerOne is offline   Reply With Quote
Old 10-09-2007, 10:41 AM   #7
gacjr0's Avatar
I like to make a loop at each end of the pack. This loop only goes around the slot, not under the chassis. Join the loops with a top piece of tape with some tension and the battery is secure. Leave the loops on for weeks at a time while only using a short piece each time the battery is removed.
gacjr0 is offline   Reply With Quote
Old 10-09-2007, 11:16 AM   #8
Trader Rating: 16 (100%+)
Oh yeah....the TAPE itself MATTERS............don't buy the fancy colored one just because it match your colored bulkhead or alum parts, get the GOOD ONE that sticks.
I have the black one from Nexxus Racing...last FOREVER...and when your batteries getting warm while running it, it sticks even better....I use 1 round of tape for multiple practice, 3 qualifier and the main....but sometime I will change to another one after then 2nd qualifier.....just a piece of mine of preventing the tape get loose.
Solara is online now   Reply With Quote
Old 10-09-2007, 11:20 AM   #9
can you use electrical tape or will that hurt the battery?
RoseTuned is offline   Reply With Quote
Old 10-09-2007, 11:24 AM   #10
timmay70's Avatar
Electrical tape is usually PVC, and is not strong enough for racing applications. One hit, and the tape will break. You need a fiberglass filament tape, or one like the Speed Merchant tape I mentioned earlier.
ROAR #105242
Old 10-09-2007, 05:13 PM   #11
thanks for the replys
i just use fiberglass tape from the local hardware store
T2 007 sedan and Corally SP12X pancar
Old 10-09-2007, 09:28 PM   #12
edseb's Avatar
That stuff doesn't work quite as good. It will wear through that stuff on asphalt. Go with the other stuff recommended above, its better; trust me, been there done that.
edseb is offline   Reply With Quote
Old 10-09-2007, 11:58 PM   #13
ok
il order a roll of that stuff
thanks for the input
PS u talking about the cars or the tape?
Old 10-10-2007, 08:48 AM   #14
timmay70's Avatar
ok
The tape, but I'm sure that all the companies that were mentioned above wouldn't mind selling you new chassis, too...
ROAR #105242
Old 10-10-2007, 09:42 AM   #15
Couple reason why the tape broke (cutted...)
(1)...carbon fiber chassis not sanded smoothly...make sure sand the battery tape slot round and smooth.
(2)....bad tape, ie, the NON-RC use fiber tape...even the 3-Com one....
Forget about electric tape...when it get warm (your batteries will get hot while running)...those tape tend to get soft. It won't break...but it will get loose. And when your tape got loose...expect to see your 6 cells flying out at the next corner....
tekin battery doctor 8.0 & fk05 battery brace xxblackheartxx2 Australia For Sale/Trade 0 04-02-2008 01:33 AM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 05:21 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
Taping batteries TAO4R Electric On-Road 22 03-20-2004 12:40 PM
