LRP TC lipo cut off? >
Old 08-29-2009, 09:38 PM
SpeedySST's Avatar
Default LRP TC lipo cut off?
I have tried to search the forums for this answer but I cant seem to find out if the LRP speed controls have lipo cut off. Please help!
SpeedySST is offline
Old 08-29-2009, 09:51 PM
I'm sure it depends on the model. Which one are you looking at?
MonkeyFist is offline
Old 08-29-2009, 11:17 PM
SpeedySST's Avatar
The TC spec and the A.I. pro reverse.
Old 08-29-2009, 11:39 PM
The TC spec I'm sure has a LIPO cut off, it one of LRPs top ESCs. The Ai I'm not sure about. It says it's lipo compatable, so I'd say it's a safe bet to say it has a cut off as well.
Old 08-30-2009, 08:15 AM
adamge's Avatar
They do, but they aren't effective at protecting lipos.
adamge is offline
Old 08-30-2009, 08:55 AM
dameetz's Avatar
Do you know why? I have the same problem with my SXX TC Spec, eversince I m using it my LiPo swells, I m suspecting the esc did not cut it off, my car just slows down to a crawl but the esc did not cut it off. I posted this q on SXX thread and yet to get a reply from that guy Burito (LRP).
dameetz is offline
Old 08-30-2009, 09:48 AM
adamge's Avatar
There are only two possibilities:
1. The internal code compares voltage to a cutoff voltage setpoint that is too low.
2. When it sees the voltage below the cutoff voltage setpoint, it doesn't actually cut off throttle in a way that the driver notices.
adamge is offline
Old 08-30-2009, 11:39 AM
dameetz's Avatar
I think you are right, the other day i put my Lipo on my charger after my run and I see it read 5.75V. On my other esc I set the cut off at 3.2v per cell. I ve been told the SXX would cut off around 6v region but in reality it goes well below it. Anyhow performance wise the SXX is very good. For precautionary I just don't run my car beyond 5 mins right know, be it continuous or have a stop during the run.
dameetz is offline
