Novarossi engines thread
#5401
#5402
You'd benefit from the larger head on the GT9 engine. I'm not sure exactly the timings between the WC and the 9-port GT engine but given the choice I'd go for the GT9 as it will suit the heavier GT car better.
#5403
New sleeve material???
Haven't use Nova engine for while, I bought 3 Nova based engine all are 2017 models. The sleeves are tight after 2L of fuel. Did they change the material?
Unlike before, the engine was much easy to break-in, now even break-in version still tight like non-break-in.
#5404
Same material but yes it's ok they stay pretty tight it's fine enjoy!!
#5405
Mito 7 is a great buggy engine, just a bit thirsty on juice. Anyone has mito 4 (both) can give their opinions?
#5407
Mito4 is fantastic on fuel. I can do 12 minutes (41021/9901). The engine doesn't have the zap of the Mito 7 of course and so on a big track or in high traction is a disadvantage. I get over 10 minutes on the Moto 7 with a 6.5 restrictor and the same pipe/manifold as above.
#5409
#5410
#5411
#5412
#5414
Legend 9 is based on the keep on 21.
#5415
Question on fuel line
I have seen longer fuel lines coming from the pipe to the Exhaust Gas Cooler compared to mine. ( picture below)
Would mine be consider short or should I make it longer ?
