Like Tree195Likes
Novarossi engines thread
Old 09-07-2017, 04:50 AM
  #5371
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by BigC2007
Can a Novarossi Exhaust Gas Cooler get clog also like the pipes and need cleaning ?
I've never had an issue with the exhaust gas cooler. I suppose it could get something blown up through the exhaust but it's unlikely. You'd know if it got blocked because the engine tune would instantly go way off. It's easy to check because it's just a straight pipe which you can see if you hold the cooler up to the light.
dan_vector is offline
Old 09-07-2017, 07:15 AM
  #5372
BigC2007's Avatar
Thanks Dan it was just a thought about it clogging, I know my has been on my car a while now and never check it out.
dan_vector likes this.
BigC2007 is offline
Old 09-08-2017, 05:14 PM
  #5373
BigC2007's Avatar
Default Novarossi VIR-TUS Tuned ?
Heard mix reviews on these motor, what your guys take on them ? Anyone
BigC2007 is offline
Old 09-08-2017, 05:38 PM
  #5374
mustangkillaz's Avatar
What are you putting this in?
mustangkillaz is offline
Old 09-08-2017, 05:42 PM
  #5375
BigC2007's Avatar
No I was just asking about them I see a website has a good sale/deal on them and just wanted to know about them, like I said I have heard both good and bad reviews about them.
But I am looking for new or pre-ran motor for my Shepherd WC V8.
BigC2007 is offline
Old 09-08-2017, 06:46 PM
  #5376
I'll have to look but depending on how much speed you want, the rex 9 .21 is a steal at the moment on novadirect
Old 09-08-2017, 06:55 PM
  #5377
BigC2007's Avatar
I seen that too, good deal on novrardirect, was just thinking of getting another PTA tuned Flash from them.
BigC2007 is offline
Old 09-08-2017, 07:04 PM
  #5378
wc35 .21 is a bargain, too. Compared to OS. Parts are also much cheaper.
Old 09-10-2017, 07:30 PM
  #5379
Anyone run Mito 35 GT5 2017? Looking for some feedback on this engine. Thanks
Hotspur is offline
Old 09-11-2017, 01:49 AM
  #5380
dan_vector's Avatar
Yes. I have the 2016 and the 2017 versions. The 2017 has a shade more torque than the 2016 version all things being equal. The only change is the liner which is basically a 7 port liner with two ports either side of the exhaust port being opened up into 2 large square ports making the 5 ports. You can 'update' a 2016 engine just by changing the piston/liner set.
Old 09-11-2017, 04:31 AM
  #5381
Thanks. And how do they compete against the other GT engines on the market ?
Hotspur is offline
Old 09-11-2017, 06:03 AM
  #5382
dan_vector's Avatar
My Mito GT5 2017 and my Ielasi Tuned Novarossi GT5 engines are both quicker than the Picco EMX-GT and GT1 engines which also run at our track. Thereís also an XRD-GT engine and that doesnít even come close. The Picco isnít far behind but Iíve got the legs on the straight and punch out of corners but this class is really clutch critical.
Old 09-11-2017, 08:53 AM
  #5383
Thanks for all the feedback. I currently run a novarossi top elite 5. 9886/41032 combo work with this or would you recommend something else?
Hotspur is offline
Old 09-11-2017, 10:26 AM
  #5384
dan_vector's Avatar
Yes. Perfect.
Old 09-12-2017, 06:03 PM
  #5385
Yes. Perfect.
And as far as plug goes what runs well? Was going to run c8tgt.
Hotspur is offline
