Turbo 35s
Turbo 35s
Could someone help me out with the differences in the Turbo 35 BL and the Turbo 35 Stealth?
Alos, $225 shipped sound like a good price?
Thanks.
Thanks.
as far as I know, the case color... I could be wrong though.. that price sounds about right..
I just checked CEI's website and per them, the only difference is the face plate graphic and the case color.. the descriptions and functions are the same..
Thanks.
Re: Turbo 35s
Thanks.
Thanks.
Go here and ask them.... CE says this site is the best place to go for info..
http://www.balakracing.com/phpBB/index.php
Ok, another question
If you could only choose one for right now......and would have to be about 6 months or longer for the other.
Would get a used Turbo 35 Stealth for $225......or a new LRP Pulsar Comp.?
Basically this is replacing a Duratraxx Digital Intellipeak so one or the other is needed lol.
Personally, the T35.. its the standard and can give you more info on your packs..
just my 2 cents
just my 2 cents
It will discharge @ your max amps.. I found this out this weekend and bought a new powersupply..
I was under the impression that you could discharge at whatever rate you wanted regardless of power supply. Why would you possibly need 30A to discharge? Am I to believe that I need a $400 charger and a $200 power supply to do the work of a $35 Integy Reactor 30?
I could be completely off here, and if you have one and this is not the case please correct me, but I believe you can discharge at whatever amperage you want regardless of powersupply amerage, however, you cannot CHARGE above ps amperage.
-G
-G
All I know is that on saturday I was disharging my cells and it would only discharge at 14amps due to that was what my powersupply was rated at..
so sunday I got a 30amp Rivergate Bulldog and it discharged at 20amps then...
I was looking at the Balrak site and they said the same thing...you can discharge at any amperage. Hmmm, maybe I will just email CE
I have only one 25 Amps power supply.
I have connected my two GFX and discharge both at 30 Amps.
So, please be aware, you need as many Amps as you CHARGE, but not when you DISCHARGE.
Ok, just to clear some things up. You can use ANY 12 volt power supply, no matter what amperage, to discharge up to 35 amps (or what ever the max of your charger is). This is because the charger doesn't need to draw 30 amps from the powersupply to discharge. The amount of amps your power supply can supply and what you can discharge at is irrelevant. Don't let anyone confuse you about this!
-etzkev
-etzkev
Some chargers run the discharge without even having been connected to the power supply, it runs off the battery.
