LRP Competition Sphere 2007 - ESC Issues
Added this to my LRP X11 6.5T Brushless, and I've changed the settings to Value 1 (Smooth Power x 1) or in otherwords, the lowest setting of the 8 values (8th being aggressive).
Does anyone know how to turn the punch down? Because everytime I drift, (putting aside the 6.5T motor as a variable), the power is either ON or OFF.
There is no "in-between" power so to speak, so I can get mid-range. For example, when I hit 10% of the throttle, its very twitchy and jerks forward. I've tried setting my throttle on the controller, but I believe the issue lies within the ESC and the ESC primarily dictates the power to the motor and the controller assists in maintaining/adjusting it.
Someone help, cause I can't seem to get it right.
Thanks for your help.
Che
Che
Have you reset your esc after making any changes? Also if you are using spektrum it would be a good idea to rebind it then reset the esc with 100% throttle dialed into your radio epa's.
Also take any arc or throttle expo's in your radio if it has them before resetting.
Thanks for that.
- When I turn the car on, the controller (MX3 FHSS) is binded already.
- Basically, I reset everything to default settings.
- Then I make the adjustments where necessary, primarily the APDC (speed control) value is set to 1 (being the lowest or as LRP label is 'Smooth Power x1).
Then I try to have a go at it and it's not working. Still way too punchy for its own good. I check the modes to make sure and its all correct.
Perhaps, I need to:
- Unbind the reciever to the controller then rebind it.
- Have the ESC Settings set with 100% throttle dialed in
- I do have ARC settings (which I've adjusted), on. Should these be changed to value 0 or something? Last I checked it goes up to 100 or so.
Perhaps, I need to:
Zero out everyhting on radio including throttle trim, arc, and such. Make throttle 100 epa.
Rebind
Reset esc as in the throttle / neutral / brake settings. for the initial setup
Dont worry about the tuning options yet.
Rebind
Okay, i'll 0 out throttle trim, arc, sub-trim etc. and make throttle 100.
Keep in mind, when you say zero out, mine can actually go past zero and into negative. So would that be 0 or all the way past 0 and -100.
I'll reset the esc to default settings as thats what I presume you're referring to.
I'll let you know how I go tonight (currently 2.36pm) at work and won't be having a look at it until I get home.
Okay so I had a chance to look at it.
I reset everything to zero and set EPA to 100. After doing so, the punch would kick in from 5% throttle.
So I HAD to turn up the Sub-Trim TH so it would be easier on the throttle which I have done so. Though, I still am kinda getting a punch on and off effect.
I tried it with default settings on the ESC and then with the Speed setting set at the lowest value..
Anyone with this ESC have an idea?
i had same problem like u before...from my experience with this prob is..u must reset ur esc profile...
mode 1=(autocell)..turn to value 1 if u using lipo
mode 2=(adpc) it's ok if u use value 1
mode 3=(initial brake) always use 0 value
mode 4=(automatic brake) always use 0 value
try this...it's my solution for my sphere 07 n still using till now from dec 08 with my drift n tc car...3 times failure operation n still can fix(my friends fix it)...still competitive till now for tc...
