Team Associated RC10B64 Thread >
Like Tree710Likes
    Hide Wikipost
Old 08-01-2017, 03:20 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10B64 Thread
Last edit by: RCBuddha
Welcome to the B64 Wiki!
Quick links to all the sections on the first page!
Petit RC Page
B64D Manual
Aftermarket Upgrades
Petit RC Page
B64D Manual
Aftermarket parts
Helpful Tips and Videos
How to properly Shim the B64 Diffs
B64 Club Racer video
Print Wikipost
Old 01-19-2017, 12:17 PM
  #631
Trader Rating: 21 (100%+)
Originally Posted by Gayosaka
I'm quite shocked by the toe-out on front! I don't think this is a lens effect.
There was some discussion about that on the JConcepts FB page earlier. It's not an illusion. Cav is running a ton of toe out. I have heard some guys saying the control tires at the Reedy race lack grip up front, and have a lot of rear grip. They are having to do some out of the box setups to have enough steering.
MX304 is offline
Old 01-19-2017, 12:23 PM
  #632
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I thought it was odd that tire was chosen vs. the Electron.
Jmuck69 is offline
Old 01-19-2017, 02:08 PM
  #633
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
I've run the transistor up front on my cars at OCRC and they lack steering. The positron in the rear is very stable and locked in. This combination makes for an easy to drive car that doesn't rotate and severely lacks steering entry, assuming you are using a relatively standard setup similar to those posted on the AE website.
A more standard setup at OCRC, which many of the locals use, would be to use an electron up front with the positron in the rear.
SEF is offline
Old 01-19-2017, 02:31 PM
  #634
JsK
JsK's Avatar
Originally Posted by Davidka
Still no vertical ball stud mounts on the rear. I wonder why AE is so adamant about this on 4wd's?
Cheaper to share hubs with the B6 would be my thought. Does leave the door
open for the BMI inserts in aluminum hubs though. Heard AE is working on there
own version of the hubs with the offest built in and there own 67mm bones.
JsK is offline
Old 01-19-2017, 02:40 PM
  #635
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Hubs aren't the same as the B6. Offset is different I believe.
Matt Trimmings is offline
Old 01-19-2017, 02:59 PM
  #636
Hubs are not the same as the B6. The offset is different.
Vertical ball studs in a plastic hub require a lot of thread engagement. With large bearings to capture the cva pin, this is not possible.
AE_Stig is offline
Old 01-19-2017, 04:36 PM
  #637
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Logi Maker is offline
Old 01-20-2017, 06:04 AM
  #638
RawSpeedSteve's Avatar
Talking
Attachment 1407500
RawSpeedSteve is offline
Old 01-20-2017, 07:06 AM
  #639
Orion_2kTC's Avatar
Trader Rating: 11 (100%+)
They should just raise the price $50 and include the Kashima shock bodies and long shock towers.
Orion_2kTC is offline
Old 01-20-2017, 07:47 AM
  #640
Davidka's Avatar
Trader Rating: 86 (100%+)
That's certainly a good reason. I'm guessing it's going to turn out like most of AE's cars. Maybe a few less available adjustments but nobody misses them, because the stock positions are the right ones.
Davidka is offline
Old 01-20-2017, 04:25 PM
  #641
Cain's Avatar
Trader Rating: 294 (100%+)
am I wrong or does it look like the rear body mount was dremeled off? Curious if they should have just made none at all?
Cain is offline
Old 01-20-2017, 06:12 PM
  #642
Jmuck69's Avatar
Dremeled off but needed to keep the body from being pushed down further. Also the antenna holder of the servo CF plate is being cut off, especially if you run the antenna-less receivers.
Jmuck69 is offline
Old 01-20-2017, 06:47 PM
  #643
Keeps the body from affecting chassis flex as much, but holds it up in case of a crash.
MX304 is offline
Old 01-20-2017, 10:50 PM
  #644
1/4milecrazy's Avatar
Not everyone wants or needs them. I wouldn't want to spend an extra $50 for them.
1/4milecrazy is offline
Old 01-21-2017, 12:32 AM
  #645
patiofurniture's Avatar
More so that driver prefer the cleaner look and convenience of not having body posts.
The CF servo/ antenna mount was specifically designed to make it easy to dremel off the antenna mount and have it look OEM after its dremeled.
patiofurniture is offline
